Argon 18 E119 Tri+ NIB Frameset
NIB Argon 18 E119 Tri + Frameset.
Price: $5,000 (MSRP is $5,750)
Overview:
  • Aerodynamic gain of 14.89% over the E-118 Next
  • Exclusive rear E-119 Tri brake - Cam-pulled system installed horizontally; aerodynamic, easy to access and adjust
  • Concealed front E-119 Tri brake - Ultralight and easy to adjust
  • Triathlon-adapted geometry, 78º seat post, and adjustable saddle position (+28mm; -28mm) - Creates an optimal fit for any level of athlete
  • Carbon lay-up even lighter than the E-119 Tri’s - Designed for highest performance and stiffness
  • Exclusive integrated handlebar with our ONEness concept - Offers greater headset adjustment, optimal aerodynamic positioning, and more than 30 configuration options
  • Additional 25mm tire clearance - Prevents the brakes from rubbing and enables faster wheel changes
  • CFD analysis (wind tunnel and velodrome testing) - Optimal aerodynamics in true wind conditions (5° to 20° yaw angles)
  • Classic derailleur hangers - Makes for easy wheel changes
  • Travel-friendly - No complicated hardware, easily removable cockpit and wheels
  • Size-specific geometry - Well balanced ergonomic fit for every frame in every size
Argon 18 E119 Tri Plus Frameset 2016 Specification
  • E119 Plus Carbon Frameset
  • Full Carbon Fork
  • Carbon Seatpost ASP-7050
  • Colours Black/Grey
  • Bottom bracket: BB86
  • Headset: FSA MR122 and MR136 bearings + oneness 3.0 compressor included
  • Removable and adjustable front derailleur hanger compatible with compact and oval chainrings
  • Forged dropouts with replaceable forged rear derailleur hanger
  • Exclusive Argon 18 integrated aero brakes
  • Triathlon accessories (nutrition, hydration, and survivability)
Additional specifics located on Argon 18 website: https://www.argon18bike.com/en/bikes/triathlon/e-119-tri-plus
Pure Grit Multisport; Triple Threat Triathlon
Re: Argon 18 E119 Tri+ NIB Frameset [Irondad11] [ In reply to ]
Where are you located?
Re: Argon 18 E119 Tri+ NIB Frameset [kevpog] [ In reply to ]
I am in Charlotte, NC
Is this still available?
Re: Argon 18 E119 Tri+ NIB Frameset [kvrodrig] [ In reply to ]
This one isn't, but I can acquire another one
PM'd you!
