Hi all, I have a Cube Streamer currently outfitted with the stock Fulcrum 7 wheels and 23mm tires. I have found a good deal on Fulcrum Quattro LGs which support 25mm tires. I am confident width won't be an issue but the rear tire is very close to the seat tube with the current 23mm tires. Do 25mm tires protrude further from the rim than 23mm ones? I was thinking of getting conti Gp4000s in 25mm to replace the same model in 23mm.
Thank you!
Thank you!
