For sale is a set of 2011 10-speed Zipp 303 Tubular.
-I bought it used, with less than 500 miles on it, and added maybe 750 miles to it since. Most of the 750 miles were on the rear wheel, which I covered for use during time trials
-This is the edition with wide rims but just before firecrest (review here); it has a bulbous, toroidal rim shape.
-I bought it used, with less than 500 miles on it, and added maybe 750 miles to it since. Most of the 750 miles are on the rear wheel, which I covered for use during time trials
-Has two Vittoria Corsa Evo tires glued on; a lot of tread left. Rear tire has a small cut, but the cut did not puncture the treat
-Front hub was replaced by Zipp in 2015
-Front mass: 818g; rear mass: 923g. Total, with glue and tires = 1741g.
WHEELS SOLD
-Can meet locally if you are in Northern NJ/NY
-I also have Catalyst carbon disc covers that will fit both this wheel and a 60mm rim (such as my Stinger 6). NDS has a small hole that is taped on. DS is combined from a large section and a smaller section near valve hole. $100 plus shipping
WHEELS SOLD
