Going to be racing with a 60-90mm front wheel and a disc, both clincher.
Wanted advice on what type of spare tubes valves to carry during the race.
Would it be one tube with a large valve extender already attached in case front wheel flats, and also a tube with a standard length presta valve in case the disc flats (the length of valve that would best fit the CO2 inflator for the disc wheel)?
If the above is the best recommended approach and if one of the wheels flats twice one would have to change the other tube valves before installing for the second flat.
Thanks in advance
Thanks in advance
