Quick saddle change for GURU DFU
Hi all,
Any one using a guru dfu and found a better way to change saddles quick instead of the original saddle clamp? To be honest i found it a bit dissapointing to have a saddle clamp without angle adjustment on such a great fit bike and it is also not really easy to switch between saddles.
Thanks!
Jeroen
Tri-Run.com
Re: Quick saddle change for GURU DFU [tri-run] [ In reply to ]
https://www.i-ride.co.uk/...erTilt-Adjuster.aspx
Retul Certified Fitter. gebioMized Pressure Mapping http://www.PedPowerPerformLab.com.
Retailer of Wahoo Fitness, Sable Water Optics, Enve Composit, Giro and more.
Zone3 USA Ambassador - use code DEAN25 for 25% off
http://www.OasisOne-Twelve.com - The ultimate hands free hydration system.
https://www.athlinks.com/athletes/19354499 - results.
Re: Quick saddle change for GURU DFU [hideano] [ In reply to ]
Does not really work until you modive the clamp that holds the saddle and even than not that great. I have one and i will work a bit more on it to see if i can get it better.
Thanks anyway for the suggestion
Regards,
Jeroen
