Andrew Coggan wrote:
1. The AIS has shown that the SRM is less sensitive to temperature-induced drift than, say, a PowerTap: https://www.ncbi.nlm.nih.gov/pubmed/15235334
(Note that the large drifts reported in this study are due to A) rapid change in temperature from 8 to 21 deg C, and B) essentially an operator error, i.e., failure to reset the zero offset when the temperature changed significantly.)
That's the point I'm making though. Temperature changes of that magnitude are quite normal. Such as doing a 1-2hr climb in the mountains, where you are unlikely to stop pedaling and zero offset. That's precisely why most major PM manufs these days implement some form of temperature compensation. So you're saying it's acceptable that the SRM user is at fault for not stopping mid-way through a climb to
Rather than swings in temperature and rough roads, in my experience (and, again, those of literally dozens attempting to use the WKO4 model) the most important "failure point" of powermeters is the difficulty many have in measuring power accurately when torque and cadence are changing rapidly. The Quarq (vs. SRM) results described in my old blog post are one example, whereas here is a scientific study comparing PowerTap and SRM during (among other tests) an 8 s sprint3) I'm finding it funny though that you're referring to units/tests from 6-12 years ago, for companies that have advanced beyond various faults. A Quarq unit today is dramatically different than one from 2013 or 2009. In fact, in my Stages review, I actually demonstrated exactly this - where a Quarq from 2008 showed the drift in a 20*F swing that I noted above during a simply climb in the mountains in California. In their specific case, they noted that was due to water ingestion in the unit through the battery compartment. But in this specific example, Stages (ignoring leg bias issues for a moment) actually did compensation for temperature correctly.
If I had more space, I'd actually build some sort of walk-in fridge/shack that I could shift the temperature automatically from something like 60*F down to 40*F, or from 80*F down to 50*F. Typical mountain climb decreases. Alas, I luck such space to do that.
My tiny little slice of the internets: dcrainmaker.com
