Carl wrote:
all single qty except as noted, most are stainless steel or otherwise anti-corrosion coated, from your Trek dealer:
W302605 (2) front brake cover bolts
W311089 rear brake cover forward bolt
W311088 (2) rear brake cover aft bolts
420693 (2) handlebar bolt kit (all spacer bolts, clamp bolts, pad holder bolts)
W308011 stem pinch bolt
W308012 front stem forward bolt
W309908 (2) front stem rear bolts
W308017 bar-stem bolt kit
Carl could you post the same for 2014 gen 2 SC9?
Is there anyaway you could post actual sizes of those bolts including seat bolts etc.
Yesterday I replaced two stripped wing pad bolts with Ti and saved 100% weight from 8g to 4g, I think I could save over 50g or more replacing them with Ti.
