Bike trainer speed vs. road speed
I have a tough time averaging much more than 30km/hr on my bike trainer, but I'll do that fairly easily on the road over a similar distance. It might also depend on how tight the clamp is on my CycleOps Fluid trainer.
What are observations from others on ST?
Re: Bike trainer speed vs. road speed [akrievins] [ In reply to ]
I use my Kurt Kinetic for intervals or base training. I find that it mimics the road resistance pretty well, but overall, getting my power numbers up is harder on the trainer. I think some of it is lack of movement of the bike and the other is that it is hard to shed the heat when riding indoors...even with 2 fans going full blast.
Bob
Speed on the trainer is relevant only so far as the resistance curve of the trainer in question. Forget speed.
It also does depend on clamping force, and tire pressure, and on the trainer you can't coast and can't get nearly as much cooling on your skin.
Really, the solution is TrainerRoad, or PeriPedal, or anything else that will estimate your power output from your trainer, then prescribe workouts based on that. Wattage is what matters.
The point is, ladies and gentleman, that speed, for lack of a better word, is good. Speed is right, Speed works. Speed clarifies, cuts through, and captures the essence of the evolutionary spirit.
Re: Bike trainer speed vs. road speed [Toby] [ In reply to ]
Toby wrote:
..... Forget speed.... Wattage is what matters.
Too true, but pretty ironic given your signature line ;)
But yeah, trainer speed is only relevant to your make and model of trainer and even things like the tires and pressure you run as well as press on force. In a general sense it has no relationship to speed on the road. But for specific trainers there can be a rough mapping like the way a Kurt Kinetic trainer attempts to emulate a 160 pound rider on a 1% uphill grade but it still won't map to flat riding in arbitrary wind conditions.
-Dave
Speed on the trainer is almost a worthless metric. Even if you ensure that every ride uses the same tire pressure and clamping force it would only be used to compare day to day trainer rides. But, that would still not have any bearing as a comparison to road riding.
Instead use RPE (good), a heart rate monitor (better) or a power meter (best) to equate trainer riding to road riding.
Re: Bike trainer speed vs. road speed [Dave_Ryan] [ In reply to ]
Great replies so far. Very good information. I'm very Impressed with ST today! :)
The two are really different. On my Computrainer I don't get to coast and the energy conserving techniques I use on the toad just don't work.
I haven't done the comparison but I definitely have to put out more on the CT than outside for the same given speed. Plus, if I decide to do a 40 Km flat TT on the Computrainer, there is no respite of any kind, I have to pretty much keep the same power output whereas on the road I'll have small bumps (or larger hills) which allow me to change cadence, pedaling style etc.
This past weekend I road for 3 1/2 hours on pathways around the city and had no issues with sore spots or anything similar. If I attempted that long a ride on my CT I would have been seeking relief from being in the same position all the time. Now, my speed outside on pathways wasn't all that great but I was out for an easier day to put in some saddle time.
BC Don
Pain is temporary, not giving it your all lasts all Winter.
Re: Bike trainer speed vs. road speed [dfroelich] [ In reply to ]
I would not call trainer speed a worthless metric when it is compared to day to day trainer rides, which can happen when outside riding is not possible. No doubt a power meter is best for trainer to road speed comparison.
My Kinetic Kurt is spot on with speed, consistent day in and day out. I usually do intervals of 2x20', 3x10' or 4x10' and aim at going 20.5mph. Each time, the effort is very similar. From looking at my power meter numbers, the effort to achieve 20.5mph on the intervals is very consistent with the power meter as well.
My tire pressure is between 100-110psi and I always turn the clamp number 5 turns after it first makes contact with the tire. Anyway, to reiterate, I think speed on the training is a good number to rely on if you don't have a power meter and your training is delivering consistent pressure as mine is.
Re: Bike trainer speed vs. road speed [125mph] [ In reply to ]
5 turns? I think the recommendation by KK is 2 1/4 turns. I've broken the "Z" bolt at 3 turns, but made a new one that has held up. I do get tire slip at 3 turns when ramping up the power. I'm not saying 5 turns isn't doable...just want to verify that that isn't a typo?
Thanks,
Bob
Re: Bike trainer speed vs. road speed [bobonker] [ In reply to ]
Thanks,
Bob
Sorry, not 5 full turns. I just turn it 5 times and each one of my turns is about 1/2 a revolution.. so that ends up being around 2.5 turns.
FWIW, the manual says 2 to 5 turns.
my KK road trainer (2.5 revs) is very close to the speed I get on my road bike with about the same power based on my quarq. The tri bike is about 2 mph faster outdoors vs trainer.
Re: Bike trainer speed vs. road speed [astig] [ In reply to ]
"I used to wait two turns before I called my baby, but now it's like everybody waits two turns and two turns has become, like, industry standard . . . "
There was a thread on this not too long ago and if I remember, the only official line was "between two and five turns", like you microwave popcorn may take 2-5 minutes. Frustrating, but the consensus seemed to be then, as now, that 2.5-3 full turns will get you close if you're using Virtual Power.
The most important think is doing it the same every time, also as noted above.
And to partially answer the OP on the speed question, I am several mph slower on the KK than outdoors; I go 3 full turns.
_____________________________________
What are you people, on dope?
—Mr. Hand
It is a worthless metric :). We don't show it in our software because it doesn't mean anything. We do allow people to export their files and speed is in there...much to my pain :).
As others have said go RPE, HR or power.
CEO at TrainerRoad
Co-host of the Ask a Cycling Coach Podcast
To answer the OPs question, on a 10min interval, I can hit about 21mph on the trainer, 25mph on my TT bike on flat course, and 23mph on road bike on flat course. All these speeds are when I'm pushing around 250 watts.
So there is a difference as far as I can see in terms of speed for similar powers.
Good comparison! Thanks!
Its a STATIONARY trainer. You should expect a speed of 0.
Trying to correlate it to road speed is fruitless. Wind resistance goes up exponentaily with speed on road, but trainer resistance increases depending on what type of non-newtonial fluid you use (and then there are magnets and fans)...
If you have a powermeter - that works best.
HR is a acceptable proxy.
Amateurs like me simply use preceived effort to compare to road riding.
Remember - It's important to be comfortable in your own skin... because it turns out society frowns on wearing other people's
Re: Bike trainer speed vs. road speed [Doubletime] [ In reply to ]
power law, not exponential. (paging ZackCapets)
Re: Bike trainer speed vs. road speed [scofflaw] [ In reply to ]
In addition to the tire pressure & number of turns of resistance on the roller, another condition enters in when the wheel/bike is removed from the trainer. The wheel must contact the roller in a marked spot each time, because no wheel is perfectly round. This does make a difference, as I have found.
Re: Bike trainer speed vs. road speed [tburke] [ In reply to ]
Wait, so I need to always clamp the roller to the wheel at, say, the valve stem?
I find the highest point on the wheel (where the tire touches the roller) & make that the mark on the wheel & tire. The valve stem likely will work also. If you have to take the tire off, put it on in the same marked spot.
True, and square wheels are the RDs' latest attempt to slow me down.
—Mr. Hand
By virtue of your CdA and tire rolling resistance you have a certain relationship between speed and power that you've come to experience as "real world riding." When you hop on the trainer you still have rolling resistance, but the trainer seeks to replace your aerodynamic drag with mechanical drag. The trainer speed-power curve is a generalized one that works fairly well for everyone, but if you're a tiny aero dude then the trainer will feel harder than riding outside, if you're a hefty dude that has a drag area comparable to a tractor trailer than the trainer will feel easy.
The speed-power curves are available for most trainers at their respective manufacturer's website. When purchasing a trainer it's worth considering this information as ultimately the "realism" of the ride is dictated by how closely the trainer's speed-power curve matches your real-world speed-power curve.
I see you Asad137!
I tweet!
