TrainerRoad
Feedback on this forum lead me to TrainerRoad (thanks!).
Now that I've signed up, I'm looking for feedback on favorite workouts. My goal is to improve a 3hr HIM bike split. I'm thinking of starting with the Advanced Build I Plan. I generally do two 90-120 minute trainer sessions per week, with a 3 hr road ride on the weekend. Any users out there with input on the Advanced Build plan? Or other TR plans?
Also looking for feedback on using heart rate or virtual power to manage intensity. Apparently, my Cateye speed/cadence sensor is not compatible with TR. Keep it simple and go with heart rate? Or pick up a Garmin GSC10 speed/cadence sensor and overhaul my electronics?
Re: TrainerRoad [GreatScott] [ In reply to ]
Get the speed and cadence sensor. Do you have an ant + stick to? If not pic that up as well.
You will get great benefit from doing Starr King and Gray
The advanced build plan will suite you well. You could switch some of those Tuesday burst workouts out with Grey (3x15 @ threshold) and Starr King (2x20 @ threshold).
Advanced build I gives you 7 hours of indoor cycling a week; a lot of that at threshold or above. If you stick with I think you will totally improve your 3 hour HIM split.
I strongly suggest using VirtualPower or getting a power meter. Best way to train in my opinion.
CEO at TrainerRoad
Co-host of the Ask a Cycling Coach Podcast
Re: TrainerRoad [Nate Pearson] [ In reply to ]
Thanks for the feedback.
I'm also looking at Novice/Experienced Competitor High Volume and, as I build towards IM, Novice/Experienced Century High Volume. I like the 3x per week format, intensity and volume of those plans.
My only holdback on virtual power is that I have to overhaul my electronics. I like the simplicity of my Cateye wireless. Am I correct that it is not compatible with TR?
I'm sure I'd learn to like a Garmin head unit such as the Frontrunner, but I'm reluctant to go there when I'm just chasing virtual power. I've thought of just adding the sensor, but not sure I want two sensors on the frame.
Thoughts on any of that?
Scott
I used this during imtx training. Indoor during the week, outside on the weekends. Garmin 910, hrm and the speed/cadence sensor. Worked well and kept it simple - just one computer for all my training.
Peaks Coaching Group Elite Coach
CVR Athlete Recruiter/Women’s Race Development
USAT/USAC/USAS/USATF Certified Coach, ACE CPT/Sports & Fitness Nutrition/Youth Fitness Specialist
Which trainer do you have?
If you have a kurt kinetic trainer you could hook at speed sensor to the actual trainer. We just have to give you the correct drum diameter but it works just as well. That way you don't have to add anything to your bike.
The novice/experienced competitor plans are good. Those are based on Carmichael's time crunch philosophy. My advice is don't bite off too much. Pick what you can do consistently and do that. Once you've got that done up the volume if you wish.
CEO at TrainerRoad
Great solution! I'm on a KK Road Machine. Which sensor works best in that application? The Garmin GSC10? How do I attach it to the trainer and find the drum diameter? Sorry for 1 million questions. I'm on the TR website now and can't find these answers (user error I'm sure).
Thanks for the input on the plans. I'll do the 8 or 20 minute test next week and go from there.
Scott
*deleted - inRide works*
CEO at TrainerRoad
On it. Just to confirm. I will order this: http://www.idahomountaintouring.com/...-sensor-161136-1.htm
Thanks again,
Scott
That's not the one I'm thinking of. I'm going to email you the correct one tomorrow morning.
CEO at TrainerRoad
Nate Pearson wrote:
We dont have that solution listed on out site, but it works!
Get the bontager ant+ speed sensor. The little magnet drops in the hole that's on the drum. I'll have to email Kurt to get the correct diameter.
When you get your speed sensor email me at support@trainerroad.com and I'll show you how to set it up.
Hey Nate,
Will this method of attaching the speed sensor on the trainer vs the bike produce a more steady power readout?
Re: TrainerRoad [heliix] [ In reply to ]
No, probably a less steady power output because it reads the data more quickly. Having it on the rear wheel and having a good heavy fly wheel makes the data naturally smooth.
My advice is to always pedal more smoothly :).
CEO at TrainerRoad
