fatbastard wrote:
I know it's not the ideal way to get things to our training logs, but.....
As for you'r success rate, that's unfortunate. I have had a 100% success rate in getting the info from the PP to the 310.
When starting up, make sure that you...(this is my routine)
-Turn the GPS to 'Off'
- Make sure that 'Fitness Equipment is 'Enabled'
- I rest the PP on my aero bars next to the 310 and press the 'Play/Pause' button to wake up the PP. I do this while pedaling. Wait for the Garmin to say 'Fitness Equipment Detected'
- At that point, I press the 'Play/Pause' button again to start the workout. The Garmin detects the start request and begins the timer and data is streaming to the 310 from the PP.
Also, make sure that you don't have the Garmin set to detect a Combo Sensor. I have mine set to Cadence Only
Those are great tips. Thanks!
I have "upgrade PP firmware" on my todo list, and then I'll try your checklist.
Also, if I set Cadence Only, do I not get speed? I see you don't have speed on your activity link, but there is an overall distance output.
____________________________________________
Virtual Run Coach
iPhone or iPad:
http://goo.gl/KoWru7 Android:
http://goo.gl/oWWkQN
