Re: LeMond Power Pilot [Nate Pearson] [ In reply to ]
Nate Pearson wrote:
We're going to add support for the power pilot. It spits out the ant data in a different way then regular power meters. We need to get our hands on one and try it out to support it.
sweet, now just add mac support :)
Re: LeMond Power Pilot [ollie3856] [ In reply to ]
Heart rate is done for Mac support, we are working on power now.
CEO at TrainerRoad
Co-host of the Ask a Cycling Coach Podcast
Re: LeMond Power Pilot [fredly] [ In reply to ]
Fredly,
Can I use the cadence sensor (ANT+) with anything other than the Power Pilot? I cannot seem to get my 310XT to see it. Would really like to have cadence info when riding outside.
Re: LeMond Power Pilot [fatbastard] [ In reply to ]
fredly; Hope you are still watching this thread. I found the firmware update on Lemond fitness facebook page but cannot get the link to work. Any way else to get the update? I tried to pm you but cannot due to a very recent change in slowtwitch forum rules, members with low post numbers cannot pm. Thanks
Re: LeMond Power Pilot [js] [ In reply to ]
The link is incorrect, you need to add a colon after the ftp. Here's the correct link:
ftp://files.lemondfitness.com/...dfitness/PowerPilot/
Re: LeMond Power Pilot [EdmanZA] [ In reply to ]
I should have noticed. Thanks
Howdy,
Sorry for the delayed response, was out of town...
As has been posted already, that link is incorrect; Facebook did as Facebook is want to do, and somehow messed with the formatting of the link after it had been working fine for a day. We appended the correct link to the FB page as soon as we were made aware of the issue, and it's the same as already posted on this thread.
Yup. I work for LeMond Fitness.
Fatbastard -
The cadence unit included with the Power Pilot is a generic ANT+ device, and should work with your 310XT. Try dropping our customer service department a line on Monday, and we can try to work through the problem with you...
Problem solved. One of your tech actually called me a couple of weeks ago to give me the new firmware update and to discuss a few other things. One of which was about the cadence sensor. The issue was that I had not switch the Garmin to look for just cadence. It was set to look for a combo sensor. Once I made this change, all was good to go.
Thanks for following up though.
Glad we were able to help. I was pretty sure we had gotten in contact with you, but saw that that post was sitting on here, so wanted to make sure.
One last thing though. When uploading to Garmin Connect, for some reason the cadence is reported as "Run Cadence".
Take a look..... http://connect.garmin.com/activity/125422512
Is there a step-by-step for how to pair Garmin 310XT with Power Pilot?
Re: LeMond Power Pilot [gilad32] [ In reply to ]
Make sure that you have 'Fitness Equipment' enabled on the 310. Turn on the 310, select 'Bike' from the mode selection page. Press the 'Play' button on the Power Pilot. This will turn the screen on on the PP. Wait for the Garmin to display 'Fitness Equipment Detected'. At that point, press the 'Play' button on the PP and begin your workout. The Garmin will display 'Timer Started' (typically 2-4 behind the PP).
This is what works for me.
"Is there a step-by-step for how to pair Garmin 310XT with Power Pilot? "
This is outlined in the Garmin manual, look for "Linking To Fitness Equipment."
If you still have difficulty, drop us a line - http://www.lemondfitness.com/contact
Edit to add:
What fatbastard wrote should work (does for me as well,) but I'm always hesitant to give step-by-step directions online for another manufacturer's product. With firmware revs being as volatile as they are, it's just safer to refer to the manual & then say "call us!" :)
"One last thing though. When uploading to Garmin Connect, for some reason the cadence is reported as "Run Cadence". "
Yikes... Honestly? No idea. I will forward this on, and see if anyone in engineering has any insight...
Just as further reference, here is an outdoor workout with the 310 and the same cadence sensor (the one included with the PP).
http://connect.garmin.com/activity/121696763
This one correctly displays as Bike Cadence.
Thanks, will see what I can figure out...
Thanks!
So no need to have ANT+ Spd/Cad or Power sensors selected as present? Or more accurately, should actually be selected as NOT present?
Was wondering if you had heard anything regarding this (Run Cad vs Bike Cad)
Any update on the capability to create workouts?
Have i missed something somewhere?
Hi Fredly,
All I want to do is get power data onto Garmin Connect but I can't get my 705 to pair with the Power Pilot. I've got an FR60 that will pair with it but won't record power data - any ideas?
Thanks
Re: LeMond Power Pilot [Seanos] [ In reply to ]
for the record, I have NEVER been able to get my Garmin (310XT) to successfully read data from the power pilot, I managed to get the 310XT to detect it, but even after repeated calls/emails with customer support it just would not work...the issue would be moot if Garmin Connect/Strava etc would support the files that the power pilot spits out but they dont.
"All I want to do is get power data onto Garmin Connect but I can't get my 705 to pair with the Power Pilot. I've got an FR60 that will pair with it but won't record power data - any ideas?"
Howdy,
The 705 does not support the ANT+ Fitness Equipment Device utility, and as a result will not interface with the Power Pilot. The Power Pilot *does not* output data as a power/wattage device, it outputs data as "fitness equipment" and will show up on a compatible device as such.
If you contact our customer service department - http://www.lemondfitness.com/contact - they will help you to get your FR60 set up.
M
"I have NEVER been able to get my Garmin (310XT) to successfully read data from the power pilot, I managed to get the 310XT to detect it, but even after repeated calls/emails with customer support it just would not work...the issue would be moot if Garmin Connect/Strava etc would support the files that the power pilot spits out but they dont. "
We're (unfortunately) very well aware of the issues that are sometimes (often?) present when attempting to interface with the 310XT, and there simply isn't anything we can do to solve them, as they are completely outside of our control.
M
Re: LeMond Power Pilot [TouringMN] [ In reply to ]
"Any update on the capability to create workouts?"
Sorry, but no update.
At this point in time (to the best of our knowledge,) the only people who have the native ability to write workout programs to the .FIT format are the folks at Peaks Coaching Group, who have invested significant resources to develop this capacity internally, and are producing excellent content.
We - and everyone other than P.C.G.- are still more or less in limbo, and the timeline for development of this resource has fallen far behind what was initially expected.
M
