Calendar
Retailers
Stack & Reach
Custom Geometry Calculator
Online Training Log
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
wheelbuilder.com disc question (moving valve)
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
fatbastardtris
Oct 6, 08 12:56
Post #1 of 6 (203 views)
Can't Post
I purchased a wheel cover from wheelbuilder.com and put it on my back wheel last week. At my race Saturday morning I went to put air in the tire. Unfortunately the tube had somehow moved and the valve was now several inches away from the opening on the disc. I wasn't able to get my pump connected and ended up doing my race with pretty low tire pressure.
Has anyone else experienced this? What is the cause? How can I fix it?
Tom A.
Oct 6, 08 12:59
Post #2 of 6 (196 views)
Re: wheelbuilder.com disc question (moving valve) [fatbastardtris]
In reply to
Can't Post
In Reply To
Just grab the cover by the opening and shift it back into position so you can access the valve stem. Pretty easy to do by hand.
bvfrompc
Oct 6, 08 13:15
Post #3 of 6 (173 views)
Re: wheelbuilder.com disc question (moving valve) [Tom A.]
In reply to
Can't Post
In Reply To
In Reply To
+1, seems like I do this a little each time I fill up the tube, easy and quick. Shouldn't be on too tight to do this unless you have taped around the edges in which case you shouldn't have this problem.
BK
Oct 6, 08 13:43
Post #4 of 6 (146 views)
In reply to
Can't Post
What Tom said. I've had covers sometimes shift so they are a bit off center but it shouldn't be able to go very far as it will stop when the fasteners come up against the first spoke. You should be able to grab the cover and twist it back so the hole lines up with the valve for filling.
If it really bothers you have a few options:
1-See if you need the shorter fasteners for a tighter fit.
2-You can add another fastener in a strategic location so it butts up against a spoke which won't allow the cover to move. A hole punch works perfectly to make new fastener holes.
3-Or, once you get the cover on, add a few pieces of black electrical tape on the border to hold it in place.
jyeager
Oct 6, 08 13:48
Post #5 of 6 (141 views)
In reply to
Can't Post
Funny that your tube had moved even though it's stuck through the valve hole in the rim....I hate it when rims reform themselves! :)
paul_tx
Oct 6, 08 14:26
Post #6 of 6 (113 views)
Re: wheelbuilder.com disc question (moving valve) [jyeager]
In reply to
Can't Post
With an actual disc wheel the tube almost never moves. I wonder why that is?
"Do you have dreams? Let me crush them for you"
Print Thread
