Bike Shops
Coaches
Fitters
Race Calendar
*NEW* Running Stores
Stack & Reach
Training Log
Triathlon Clubs
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
Wired Powertap Harness Questions
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
scomosr
Nov 14, 09 9:22
Post #1 of 8 (237 views)
Can't Post
I have an older Powertap with no carbon windows wired. It has the squarish hub pickup. I ordered a new harness to put on my other bike and it has the sharkfin type pickup. I can not get it to pickup the hub signal. Are they not compatible? If not, does anyone sell the older style harnesses any longer?
Thanks in advance for any help on this matter.
Scott
scomosr
Nov 14, 09 9:28
Post #2 of 8 (234 views)
Re: Wired Powertap Harness Questions [scomosr]
In reply to
Can't Post
As a little more info here is the harness info I bought:
For all wired PowerTaps
Includes receiver/stem/handlebar mounts with wired cadence sensor and magnet.
596
Nov 14, 09 9:53
Post #3 of 8 (227 views)
In reply to
Can't Post
I bought a used wired PT and it came with 2 harnesses. One was the sharkfin and one was the squarish one. They both work perfectly. But my hub is a carbon window model.
Paul
http://casasedona.com
AAA 4-Diamond Bed and breakfast Inn
As seen on the "Travel Channel"
2008 "1,000 Places to See Before You Die"
jaretj
Nov 14, 09 10:03
Post #4 of 8 (220 views)
In reply to
Can't Post
I've got an older hub that came with the square pickup. It's the silver one with the black cap.
I replaced it with the sharkfin one and it works fine.
jaretj
2010 Races:
Triple T
Long Course Nationals
http://jaretj.blogspot.com
scomosr
Nov 14, 09 11:24
Post #5 of 8 (202 views)
Re: Wired Powertap Harness Questions [jaretj]
In reply to
Can't Post
Hmm. Weird. Maybe I need to make sure I had the head unit clipped in solid. Thanks for all the help!!
jaretj
Nov 14, 09 12:14
Post #6 of 8 (179 views)
In reply to
Can't Post
Check to make sure all the pins on the base and bottom of the computer are clean and making good contact.
Make sure the batteries in the hub are good. If you have the same old hub that I have it takes an "N" type battery. I found them at a CVS drugstore.
Other than that I've got one hub that has to be right next to the sensor in order for it to work.
Check the wiring for any kinks that may result in broken wires.
If that doesn't work you may need to contact Saris about this issue.
jaretj
2010 Races:
Triple T
Alex Simmons
Nov 15, 09 0:01
Post #7 of 8 (135 views)
In reply to
Can't Post
On the really old model PTs and pick ups, the pick up had to be mounted 6-8 inches from the hub. The "newer" square and shark fin models need to be much closer to hub. But it
should
still work.
_________________________________________________________________________________
Cyclist Training Plans
Power Meter Hire
cyclecoach.com
My Blog
Sydney Turbo Studio
FiveThirteen
Nov 15, 09 1:36
Post #8 of 8 (130 views)
Re: Wired Powertap Harness Questions [Alex Simmons]
In reply to
Can't Post
I have the same older style hub and both the square and sharkfin pickups work fine. As the poster above suggested, play with the positioning until it works. You could have just received a dud wiring harness too in which case just call Saris (happened with a brand new heart rate strap I bought from them). Their customer service is top notch.
Print Thread
Tri mags
To what print mag(s) are you likely to subscribe to during 2010/11?
Triathlete
Inside Tri
Lava
Tri and IT
Lava and Tri
All
None
