Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Vision Tech Brake Cables
  Tri ForumClassifiedsLavender RoomJobsThe Womens
barelysub4
Dec 18, 05 12:44
Post #1 of 14 (400 views)
Vision Tech Brake Cables Can't Post
Does anyone know if these are unique to Vision brakes or can you use any brake cable with them? Thanks
sphere
Dec 18, 05 12:46
Post #2 of 14 (398 views)
Re: Vision Tech Brake Cables [matts] [In reply to] Can't Post
Any will do. And if you're just installing the aero brake levers for the first time, you'll want to take a dab of grease and pack it into the rivet on the lever - both sides - to keep it from rattling. Works like a charm.
"The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised." - George F. Will
jmhtx
Dec 18, 05 12:54
Post #3 of 14 (392 views)
Re: Vision Tech Brake Cables [DualFual] [In reply to] Can't Post
The end of the vision is much smaller than that of a road bike, are you sure any will do?
sphere
Dec 18, 05 13:00
Post #4 of 14 (389 views)
Re: Vision Tech Brake Cables [jmhtx] [In reply to] Can't Post
There are at least three different "ends" to brake cables, probably more. You can buy that small head cable just about anywhere. So, no, not "any" cable will do, but the cable is not exclusive to Visiontech.
GO
Dec 18, 05 14:41
Post #5 of 14 (340 views)
well...Vision does have their own brake cables that would fit right into the slot. I have also bought some after market ones as well that fit right in. However, i have used other brake cables with a bigger head. It works as long as u dont mind having the "head" sticking out. But it doesnt look right.
ms6073
Dec 19, 05 5:57
Post #6 of 14 (299 views)
Re: Vision Tech Brake Cables [GO] [In reply to] Can't Post
In Reply To
Well not in my experience (grin)! When I got the wife and I new TT frames earlier this year, I found that due to the internal cable runs, the rear brake cables for both our bikes were no longer adequate length and needed new cables for the rear brakes. The VisionTech brake levers use cables with a 4.5mm x 4.5mm cable end and after visting 3 high end shops here in Houston, not one of them stocked brake cables with the smaller cable end for the VisionTech TT levers! Fortunately the staff at another shop I visited later in the week - a shop that is starting to do some good tri/tt bike business - was nice enough to sell me the cable set out of the box of a new set of brake levers but if someone needs to order them, they are referenced in VisionTech documentation (http://www.visiontechusa.com/downloads/TS-VT-007.pdf) as follows but my understanding is unless you locate a suitable replacement at QBP or another distributor, you will need to contact FSA to order replacements:
Only use the VisionTech "Red-Dot" brake cables provided with the Vision Brake Levers. If replacing the original cables, then it is necessary to purchase and install VisionTech "Red-Dot" replacement cable-sets (Item 670-3785). Vision Tech "Red-Dot" brake cables are easily identified by the red cable end [FIGURE B].
________________________________________
Michael - Cogito Ergo Sum
"The devil has put a penalty on all things we enjoy in life. Either we suffer in health or we suffer in soul or we get fat." Albert Einstein
(This post was edited by ms6073 on Dec 19, 05 5:59)
NYCTri
Dec 19, 05 6:23
Post #7 of 14 (288 views)
Re: Vision Tech Brake Cables [ms6073] [In reply to] Can't Post
seems they look mightly similar to shifter cables...
JW
Deus ex Machina
Dec 19, 05 6:26
Post #8 of 14 (286 views)
The Vision Tech brake cables are just the Shimano ended SHIFT cables. VT does paint the tip red to give it appeal when inserted, but it is just a plain old SHIFT cable, available almost anywhere.
Don't believe the rest of the nonsense you hear. Nobody is going to go out and make specialized cables for their system. Everything revolves around four types of ends: Mtn Brake, Road Brake, Shimano Shift, Suntour Shift.
barelysub4
Dec 19, 05 6:51
Post #9 of 14 (275 views)
Thanks all, I really appreciate it!
ms6073
Dec 19, 05 7:21
Post #10 of 14 (260 views)
Re: Vision Tech Brake Cables [Deus ex Machina] [In reply to] Can't Post
In Reply To
Now your talking! But not to be contrary (just nit picky) and it probably will not make a bit of difference, but Shimano shifter cables (or at least Dura Ace) are 1.2mm diameter while the VisionTech cables are 1.5mm:
ineed2ride
Dec 19, 05 7:37
Post #11 of 14 (245 views)
If you would like to risk it by using thinner shifter cable have at it.
I would rather have the right stuff. BTW it only costs like 9 bucks or so. Alot cheaper than a hospital visit because of a shifter cable snapping at 24 miles and hour.
albush1
Jul 4, 08 21:46
Post #12 of 14 (184 views)
Re: Vision Tech Brake Cables [ineed2ride] [In reply to] Can't Post
Hello everyone. I'm in a pinch and need Vision Tech inner brake cables and no local stores have them. I do, however, have shifter inner cables which seem to fitr perfectly. Has anyone had success, or not like the shifter cables breaking, while using shifter cables (inner wire) on Vision Tech brake levers? Thanks, Adam
the fonz
Jul 5, 08 0:47
Post #13 of 14 (166 views)
Been using shifter cables for over a year now. No problems yet.
Is it possible to produce enough force with one hand to break a shifter cable? Even with the leverage of a brake lever, you never pull so hard as to lock up the brake.
JollyRogers
Jul 5, 08 2:01
Post #14 of 14 (162 views)
Re: Vision Tech Brake Cables [NYCTri] [In reply to] Can't Post
In Reply To
They do, but the cable diameter is wider. Some brakes won't hold the narrower cables all that well.
Off Season
What will you do in the off season?
Bike focus
MTB or 'cross
No training
Run focus
Swim focus
What offseason?
XC ski or snowshoe
