Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Trek TTX is Faster Than the P3C
First page Previous page 1 2 3 4 5 6 7 8 9 10 Next page Last page  View All Tri ForumClassifiedsLavender RoomJobsThe Womens
Rappstar
Oct 10, 07 11:07
Post #51 of 236 (3436 views)
Re: Trek TTX is Faster Than the P3C [jens] [In reply to] Can't Post
In Reply To
In Reply To
Yeah...a CdA of ~0.25 - 0.26 does seem a bit high for Levi. But, like I've said, not knowing the details of the comparison, it's tough to put any value on the differences shown in that chart. I'm thinking the comparison may actually have been from Basso (who would've had a P3C to compare to, right?).
Do you remember this photo:
Note the yellow drag history that the rocket scientists at Pezcyclingnews neglected to blur out. Way back when I pixel counted that to determine that Basso's drag was, in fact, .254. I think I posted the calcs here and on weightweenies somewhere at the time.
-- jens
  Well Basso is the obvious choice anyway, as he'd definitely have numbers for a P3C and for a TTX. Duh... Only question is, were they from different tunnel runs? If so, that would seem to neglect *some* of the credibility...
"BAM!" - Larry Williams | blog.rappstar.com
Ask me about: ???? Bikes :D | Zipp | True Motion | Kiwami | SRAM | TargeTraining | CycleOps Power | PBN | 1st Endurance | Normatec MVP
Rappstar
Oct 10, 07 11:08
Post #52 of 236 (3430 views)
Re: Trek TTX is Faster Than the P3C [zebragonzo] [In reply to] Can't Post
In Reply To
As to why it matters...because when people go and buy a new bike, lots of people would rather spend the money on what is proven to be the fastest. They may not be right, but it definitely exists!
  Of all the people to reply to when making that statement, you pick me?
Tom A.
Oct 10, 07 11:09
Post #53 of 236 (3425 views)
Re: Trek TTX is Faster Than the P3C [Rappstar] [In reply to] Can't Post
In Reply To
In Reply To
In Reply To
The stats are not for the TTX, but rather the new TTX SSL.
Ummm...aerodynamically speaking (i.e. the "stats" shown in that plot), the TTX and TTX SSL will be identical.
  Nope, the frames are in fact different (at least 07 TTX vs. 08 TTX SSL; not sure if they made the changes to all TTX models for 08). New fork, new downtube placement, and some other changes. They cover them in the article.
Neither article, and most notably the Trek press release, says anything about changes between the '07 TTX and the '08 TTX SSL models besides the work done to lighten the frame. Then again, you have first hand experience with the 2 models, right? So...what are the differences?
Carl
Oct 10, 07 11:38
Post #54 of 236 (3389 views)
Re: Trek TTX is Faster Than the P3C [Tom A.] [In reply to] Can't Post
part of the confusion (here and in numerous other threads) is the generic use of "TTX". There are three basic model families, across a couple years of production:
TTX - the original, roadie geometry, 1-size only
Equinox TTX - inspired by the above, steeper geometry, several other diffferences (1.125 steertube fork, some tube shape deltas both subtle and obvious, etc)
Equinox TTX SSL - lightweight version of the above
I claim no knowledge of head-to-head aero differences between the first one and the following two. But absence of evidence is not evidence of absence :-)
Carl
Trek Speed Design
MuffinTop
Oct 10, 07 11:53
Post #55 of 236 (3370 views)
In Reply To
That's what I find a bit odd about the graph. Tunnel time is expensive - who would bring two other essentially random bikes along to test? It's not like Lieto OR Basso OR Leipheimer would be in a position to say "you know what, I think I will ride the plasma this year" if it had tested faster. I guess I can see bringing the P3C for Trek's marketing purposes, but the plasma? It just seems weird to me.
Not to say that anyone involved in the production of this graph has done anything untoward, it just seems odd.
"Oh no, it's the dreaded Muffin Top!" --Mythbusters
http://www.awesome-software.net
c.dan.jog
Oct 10, 07 12:01
Post #56 of 236 (3358 views)
Re: Trek TTX is Faster Than the P3C [MuffinTop] [In reply to] Can't Post
Isn't the Plasma supposed to be really light? I'm pretty sure Scott's saying something to that effect.
If so, maybe Trek is trying to say, "Look at the TTX, it's lighter than the Plasma and more aero than the P3C. Have your cake and eat it too!"
www.wmds-unleashed.com
Rappstar
Oct 10, 07 12:10
Post #57 of 236 (3343 views)
Re: Trek TTX is Faster Than the P3C [Carl] [In reply to] Can't Post
In Reply To
Carl
  Carl, in the article, it says "Now we've opened the flood gates of debate there are a couple of key features that make the TTX an interesting Time machine. At the all important front a wider bladed fork blade allows air pulled along by the tyre, rim and spoke to pass more freely through the fork. This is most noticeable at the wider crown and the dropouts where the blades sit behind the hub end of the spokes. The smooth lines of the fork's crown are also designed to flow into the profile of the downtube. The lower downtube has also been placed in such a way as to minimize the gap between the front wheel. Cable routing is directed behind the stem and into the frame to complete the clean, aero flow at the front."
I bolded the stuff that is noted as being different. Now, is this a difference between the Equinox TTX and the original TTX? OR between the 07 TTX and the 08 TTX SSL?
Andrew Coggan
Oct 10, 07 12:17
Post #58 of 236 (3335 views)
In Reply To
Which raises an interesting question: what are the odds that the bike was tested using a HED3? (I now need to go look again at that pic that Jens posted.)
jens
Oct 10, 07 12:48
Post #59 of 236 (3300 views)
Re: Trek TTX is Faster Than the P3C [Andrew Coggan] [In reply to] Can't Post
In Reply To
In Reply To
It appears to be a Bontrager Aeolus front. Here's the whole article:
http://www.procyclingnews.com/...ullstory&id=4807
This is pretty clear about the comparison between the frames. They even matched up his outline on the screen to make sure he was in the same position on each frame
-- jens
(This post was edited by jens on Oct 10, 07 12:50)
Andrew Coggan
Oct 10, 07 13:11
Post #60 of 236 (3280 views)
In Reply To
In Reply To
In Reply To
Thanks - I thought as much after looking at the small pic you posted, but it's absolutely clear from the article.
In Reply To
Hmm...what about the claim that the bikes were set up identically, then? If you look closely at the pic of Basso on the P3C, it appears that that bike was fitted with VisionTech bars (which is what you'd expect, VisionTech being a sponsor of Basso's previous squad, i.e. CSC).
His wrist angle also appears different on the two bikes, but I'm less confident of that conclusion than the one above.
(This post was edited by Andrew Coggan on Oct 10, 07 13:14)
Tom A.
Oct 10, 07 13:23
Post #61 of 236 (3255 views)
In Reply To
Aha! Photographic proof that my speculation (Basso for the data vs. Levi) about the rider subject has a firm basis. Of course, I can understand why Trek would be a bit hesitant to say that the numbers come from Basso...
Tom A.
Oct 10, 07 13:36
Post #62 of 236 (3232 views)
In Reply To
Hey Jens...can we "Tom Sawyer" you into pixel counting the drag history in this pic to see if the baseline on the P3C is higher by the amount claimed? :-)
rmur
Oct 10, 07 14:34
Post #63 of 236 (3185 views)
dang it Tom, don't they know we country folk can back-calculate CdA as well as 'dem town folk? And cipher out who's tiny and who's not?
_________________________________
Gizmo marketing specialist :-)
jens
Oct 10, 07 14:53
Post #64 of 236 (3168 views)
Well, just putting my micrometer on the screen and measuring the ratio of the low point of the yellow drag history vs. the height of the graph, I get 15mm/20mm for the P3C and 5mm/7mm for the Trek.
That would give the Trek 5% less drag.
-- jens
jens
Oct 10, 07 14:56
Post #65 of 236 (3166 views)
In Reply To
-- jens
Wait, no what a dumb***. The scale doesn't start from zero. It goes from 2000 to 3000, so it would be a third of that: 1.6%
-- jens
Tom A.
Oct 10, 07 15:22
Post #66 of 236 (3143 views)
In Reply To
In Reply To
-- jens
-- jens
Heh heh...1.6% of 1950g is ....ta da! 31 grams. Yup...the evidence is mounting that the plots of the P3C and TTX are from Basso's runs. I'm thinking the Madone run is possibly from the same session...but probably not the Plasma.
Thanks Jens!
Rappstar
Oct 10, 07 16:17
Post #67 of 236 (3117 views)
1.6%? But I thought someone said "the top frames only have 0.2% difference between them?" ;)
Large
Oct 10, 07 16:36
Post #68 of 236 (3098 views)
You're kidding right? One guy puts a micrometer up to his computer screen and you're willing to make frame choices based on this?[code]
Tom A.
Oct 10, 07 16:42
Post #69 of 236 (3089 views)
In Reply To
Aaah...but the photographic evidence revealed that the setups were NOT truly identical (different bars, right?)...maybe the difference is just the bars?? :-)
Tom A.
Oct 10, 07 16:42
Post #70 of 236 (3087 views)
Re: Trek TTX is Faster Than the P3C [Large] [In reply to] Can't Post
In Reply To
Is this a great country, or what? :-)
Rappstar
Oct 10, 07 16:43
Post #71 of 236 (3087 views)
In Reply To
  Maybe I'm doing that. Or maybe I'm going by the fact that the micrometer up to the computer screen supports a whole slew of other data that supports the same conclusion, unlike your "0.2%," which I'm pretty sure is a number you just pulled out of your ass.
Large
Oct 10, 07 17:09
Post #72 of 236 (3063 views)
Of course. That's where I get all of my numbers.
Rappstar
Oct 10, 07 18:12
Post #73 of 236 (3025 views)
In Reply To
  That's nothing to be ashamed of around here. :)
Large
Oct 10, 07 18:19
Post #74 of 236 (3019 views)
On the contrary, I think it's expected.
In all seriousness, my only point is this. Assuming that Trek didn't fudge the chart to their benefit, the only thing that this graph represents is Chris Lieto, on that day, in that particular configuration. I would venture to say that if they changed his body position, those graph lines would look very different (and their order might even change.) The same would be true if they changed the position of his water bottles, etc. And the same would certainly be true if they put a different rider on those bikes. Therefore, I don't think any of us can draw valid conclusions about how these bikes would perform for US from this data. There are simply too many other variables at play once one gets on one of the top few bikes. Once one gets to a certain level, the only way to really tell is to individually visit a wind tunnel.
jens
Oct 10, 07 19:43
Post #75 of 236 (2976 views)
As we've discussed, that graph probably doesn't represent Lieto. It's more likely Basso.
And yes, it's quite possible that a different rider -- particularly one who pedals with his legs at a different width -- would interact differently with the two frames. But , Ceteris Paribas (that's Economist-speak for "let's assume away everything"), I would put my money on the Trek.
- jens
Your tri bike position
Your biggest need is more:
Comfort
Power
Aerodynamics
It's perfect
