Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
PLEASE HELP changing aerobars
  Tri ForumClassifiedsLavender RoomJobsThe Womens
tri-a-3some
Oct 5, 08 20:01
Post #1 of 9 (195 views)
PLEASE HELP changing aerobars Can't Post
I am in the middle of changing aerobars and am stuck on something. I have the part of the shifter(shimano) off that is attached to the cable but the other part that is actually attached to the bars wont budge. There is a little screw down in the piece but am not sure what it does, will it break ot or crack the bars?? What do I do
Thanks
SUBU~Show Up Blow Up
(This post was edited by pcolatri on Oct 5, 08 20:03)
musky48in
Oct 5, 08 20:05
Post #2 of 9 (189 views)
Re: EASE HELP changing aerobars [pcolatri] [In reply to] Can't Post
Are you talking about the allen bolt that is inside. Can't really see it, just have to stick the allen wrench in and turn. Go to Shimano's web site and it will show you in great detail.
tri-a-3some
Oct 5, 08 20:08
Post #3 of 9 (185 views)
Re: EASE HELP changing aerobars [musky48in] [In reply to] Can't Post
yes thats what im talkin about, it is REALLY tight. It won't hurt anything??
thank you
musky48in
Oct 5, 08 20:11
Post #4 of 9 (183 views)
Depends on who originally tightened them. I worked on mine a couple of months ago, but I don't remember them being that tight. I guess you could strip any allen bolt. if it's that bad, might want a wrench at your lbs to take a look.
musky48in
Oct 5, 08 20:15
Post #5 of 9 (177 views)
Opps, I need to read a little better. You do have to be careful with carbon, but once you are to the point of re-tightening it, I guess I would just go far enough to where the shifter does not move. If it moves later down the road, it's not the end of the world. Just tighten it a little more.
stal
Oct 5, 08 20:17
Post #6 of 9 (176 views)
Re: PLEASE HELP changing aerobars [pcolatri] [In reply to] Can't Post
That bolt might be reverse threaded (in other words, rightey-loosey and lefty-tighty). Look at the shimano installation instructions for that specific bar-end shifter to confirm/deny.
My training
rrfr
Oct 5, 08 20:55
Post #7 of 9 (150 views)
what STAL said; believe that's a left hand threader.......
"To be great, one does not have to be mad, but definitely it helps." Percy Cerutty
mckenzie
Oct 5, 08 22:34
Post #8 of 9 (138 views)
Re: PLEASE HELP changing aerobars [rrfr] [In reply to] Can't Post
that's correct, the threading is 'backwards' from your position on the outside of the aerobar extensions.
i just built up a tri bike a few weeks ago. i ended up losing the expansion bolt in the extensions on the first try.
mckenzie
foots
Oct 6, 08 6:33
Post #9 of 9 (79 views)
Re: PLEASE HELP changing aerobars [mckenzie] [In reply to] Can't Post
Yep, it's threaded backwards. Requires a 6mm allen wrench.
Off Season
What will you do in the off season?
Bike focus
MTB or 'cross
No training
Run focus
Swim focus
What offseason?
XC ski or snowshoe
