Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
P4 Drag Numbers
First page Previous page 1 2 3 4 5 6 7 8 9 Next page Last page  View All Tri ForumClassifiedsLavender RoomJobsThe Womens
trail
Sep 27, 08 18:29
Post #26 of 208 (2377 views)
Re: P4 Drag Numbers [sergio] [In reply to] Can't Post
Jamis also missing. I'd like to see any Jamis #'s given all the wild claims about it.
Francois
Sep 27, 08 18:30
Post #27 of 208 (2377 views)
Re: P4 Drag Numbers [ksull] [In reply to] Can't Post
you're missing a walser on that list...
ksull
Sep 27, 08 18:38
Post #28 of 208 (2356 views)
Re: P4 Drag Numbers [Francois] [In reply to] Can't Post
yea put that in too. The new Fuji as well. Just put any in missing ;)
Kerry Sullivan
USAT,USACII, CSCS, NLP practitioner
http://www.triathlonsummit.com
ston_ar
Sep 27, 08 18:42
Post #29 of 208 (2342 views)
Re: P4 Drag Numbers [Andrew69] [In reply to] Can't Post
Math check
100g of drag is about equal to 13.4 watts at 30mph?
100g=.98N 30mph=13.4 m/s
W=Nm/s
W=.98*13.4/1
or is my physics as rusty as I think it is?
Another quick question, about how many watts would it take to hold 30mph on a bike like this 450? 500? something in that range?
ACTN3
Sep 27, 08 18:42
Post #30 of 208 (2341 views)
Re: P4 Drag Numbers [Tom A.] [In reply to] Can't Post
By interpolation, it seems like P4 is slower than P3 and P2 at -15 yaw. Maybe that's why they clipped the P4 curve before that datum. Not that it particularly matters more than a hunch.
"Consistency is the last refuge of the unimaginative." Oscar Wilde
sergio
Sep 27, 08 18:49
Post #31 of 208 (2323 views)
Re: P4 Drag Numbers [ttx_tri] [In reply to] Can't Post
and what does (test 0813) means, i was very curious about that. it also seems that not every data on that chart isnt from the same test, like the P4 for example...
Sérgio Marques
When it hurts is when it feels good ;-)
Sergio-Marques.com
MITaerobike
Sep 27, 08 19:06
Post #32 of 208 (2287 views)
Tom,
Though I agree with you that the fixed offset looks conspicuous, bikes with similar shapes can test that way (and balance offsets can show the same thing...). But from experience I would imagine that offset is probably from a bar-set being 2cm higher up than on the P3C and a slight (maybe 10 grams) difference due to the rear wheel cutout.
My biggest curiosity is whether the bikes are set up to be ridden the same way (i.e. same rider position) or just how their geometries come.
I find the large jump in drag at -12.5 degrees curious. I wonder if that's a stall point or just bad data. If tested with a disc out back, I wouldn't expect that stall to hit until a bit later.
I do have Transition vs. P3C data. I've been reluctant to post as we only had time to test the bikes versus one another -- we didn't have a ton of competitors bikes, etc.
Mark
MOP_Mike
Sep 27, 08 19:10
Post #33 of 208 (2275 views)
Re: P4 Drag Numbers [ston_ar] [In reply to] Can't Post
In Reply To
Math check
W=Nm/s
W=.98*13.4/1
Math looks good. It translates to around 1 sec per km.
By crude estimate, based on an average 70 Kg rider, position and equipment, it would take around 450 watts to hold 30 mph.
So, yes, if you're implying that the new frame gives less than 2.5% advantage to the rider, you'd be correct. But...2.5% is huge at the pointy end of a TT. :)
"...if you are pedaling correctly, it doesn't matter what cranks are on your bike." -- Frank Day
(This post was edited by MOP_Mike on Sep 27, 08 19:29)
ston_ar
Sep 27, 08 19:19
Post #34 of 208 (2255 views)
Re: P4 Drag Numbers [MOP_Mike] [In reply to] Can't Post
Makes me look forward to when I can scrape enough money together to get a full areo set up and drop a couple hundred gs of drag :D. Might as well tap out my current equiptment in the mean time.
Tom A.
Sep 27, 08 19:20
Post #35 of 208 (2253 views)
Re: P4 Drag Numbers [MITaerobike] [In reply to] Can't Post
In Reply To
Tom,
Mark
...And????? ;-)
sib1
Sep 27, 08 19:20
Post #36 of 208 (2250 views)
In Reply To
More than anything, I'd like to see all of the bikes pictured as tested. Does anyone know how the bikes were tested (i.e. w or w/o disc wheels, cables?, P4 tested with bottle, etc.)?
It's easy to see 50-150 gram differences in the tunnel due to stem variations, steerer lengths, etc.
And an additional repeat of one or more bikes would be great too.
Looks like the frame and fork are a huge improvement over the P3C, no doubt. I bet they gain 75-100 grams of drag just from improved tube shapes (especially the fork).
Mark
  exactly.....and what is the likelihood that they all used the same saddles, same stems, same aerobars, etc etc.....considering that could make all the difference in the world. then there's saddle height, and relative saddle heights that will be better/worse for each bike, etc etc. could a tall rider benefit more from one frame than a short rider etc etc? interesting stuff but i just don't see how you can ever get accurate results across the board that you can apply to the general audience.
MITaerobike
Sep 27, 08 19:28
Post #37 of 208 (2238 views)
I don't have image hosting or an FTP site setup -- just a couple of minutes...
Mark
Tom A.
Sep 27, 08 19:44
Post #38 of 208 (2209 views)
In Reply To
Tom,
Exactly...and that's why it's important for the bikes to be tested in as exact the same config as possible. In that case, the P3 SHOULD have had some spacers in place for a "true" comparison.
This is what I was talking about when I mentioned "sandbagging"...for example, let's say someone is comparing a frame that has behind the stem cable entry to another that has cables entry on the sides of the downtube. It would be pretty easy to add some drag to the second model just by not being extra careful with how short the cables are, right?
In Reply To
That also brings up the question of what particular wheels were used to generate this data...
Tom A.
Sep 27, 08 19:49
Post #39 of 208 (2196 views)
Re: P4 Drag Numbers [sib1] [In reply to] Can't Post
In Reply To
In Reply To
Mark
Well...now IMHO, that's a bit over the top. You can get plenty of useful information from all of this...but in the end, it will still come down to individual testing, either in a tunnel or field testing, to get the absolute best setup for each person.
But, it's always good to know you aren't starting out with a "dog" in the first place ;-)
jackmott
Sep 27, 08 20:16
Post #40 of 208 (2151 views)
Re: P4 Drag Numbers [In reply to] Can't Post
I wonder if Cancellara sees this and is a wee bit saddened, heh
flying wombat
Sep 27, 08 21:02
Post #41 of 208 (2124 views)
Re: P4 Drag Numbers [jackmott] [In reply to] Can't Post
I am sure that the extra money that Saxo Bank can afford to pay Fabian next year will help to dull any pain he might be feeling............
Does this data break the posting rules that Rappster put up for manufacturers data? I see no tunnel speed, humidity, temperature, procedure and with what wheels, stem, bars or anything else the bikes were tested.
Kevin
tri-mesa.com
paragoncycling.com
tegra
Sep 27, 08 21:42
Post #42 of 208 (2076 views)
Re: P4 Drag Numbers [flying wombat] [In reply to] Can't Post
i was about to say the same thing.
Sojourner
Sep 27, 08 22:12
Post #43 of 208 (2051 views)
Am I reading these graphs wrong, at 0 degrees is the Felt DA listed at 725 grams of drag in one chart and 700 grams of drag in the next?
p.VDB
Sep 28, 08 0:09
Post #44 of 208 (1998 views)
Re: P4 Drag Numbers [Sojourner] [In reply to] Can't Post
In Reply To
  No the curve of the Felt DA is different between those two graphs!!
Where is the Cervelo P1? Is it that bad?
Where is the Trek TTX? Is it that good? Like on the white paper of trek beating the P3C?
1. P4?
2. TTX?
3. P3?
Hmmm, TTX frameset is available in a wide range of prices :-)
_________
Paul
tonyoh
Sep 28, 08 0:15
Post #45 of 208 (1996 views)
What about the extra drag you generate reaching way down to pick up your drink bottle, including the weaving all over the road? And then trying to put it back in???
ancientdude
Sep 28, 08 0:23
Post #46 of 208 (1993 views)
Everything in life is a matter of perpsective.
From my side of the room the table may look longer than from your side. It's hard to base a purchase simply on a paper released by the company trying to sell you the product. Of course they want you to buy their product! Everyone does.
ajo
Sep 28, 08 3:44
Post #47 of 208 (1929 views)
Re: P4 Drag Numbers [ancientdude] [In reply to] Can't Post
Cervelo has done a marvelous marketing job here. Even producing a graph showing that all their bikes are the fastes.
While I don't know anytning about the test itself, I know it's easy to "prove" that one product is best - just remove better products from the test/list.
(Look, BP Stealth, Trek, Ceepo, Wilier, Walser, Ridley... I don't know if they are faster, but it makes my suspicious that these are not included....)
(This post was edited by ajo on Sep 28, 08 3:48)
seismic
Sep 28, 08 4:43
Post #48 of 208 (1877 views)
Re: P4 Drag Numbers [ajo] [In reply to] Can't Post
In Reply To
  I totally agree! It is amazing how much value people put into a test made by Cervelo showing that their bike is the fastest.
itri-45
Sep 28, 08 5:34
Post #49 of 208 (1823 views)
It may not be possible to test against every latest frame out there but the newer Orbea Ordu has been around two years now so I'd prefer to see it included, instead of the older and lower-tier Ora. The comparison doesn't seem fair.
Duke
(This post was edited by itri-45 on Sep 28, 08 5:42)
zebragonzo
Sep 28, 08 6:26
Post #50 of 208 (1779 views)
Thanks for putting that graph up!
What I'd really like to see is some data for a bike from that graph that has been tested (ideally independently) by someone else to allow for a comparison.
The Pro Effect
Which male pro is most likely to influence your buying decisions
Al Sultan
Alexander
Andersson
DeBoom
Frodeno
Gomez
Kemper
Lieto
Lovato
McCormack
Other
Potts
Rapp
Reid
Sindballe
Stadler
Whitfield
