Calendar
Coaches
Fitters
Retailers
Triathlon Clubs
Stack & Reach
Custom Geometry Calculator
Training Log
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
Over Cross-Chaining?
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
TrueGrit
Nov 6, 09 16:58
Post #1 of 14 (305 views)
Can't Post
What do you consider over cross-chaining)? Small ring in front and 7th, 8th, 9th and/or 10th smallest in rear? Big ring in front and 7th, 8th, 9th, 10th biggest in rear? I'm thinking 7th or 8th is OK...9th or 10th is overly cross-chained.
(This post was
edited
by TrueGrit on Nov 6, 09 17:33)
prd
Nov 6, 09 17:17
Post #2 of 14 (289 views)
Re: Cross-chaining? [TrueGrit]
In reply to
Can't Post
10/2=5
TrueGrit
Nov 6, 09 17:27
Post #3 of 14 (281 views)
Re: Cross-chaining? [prd]
In reply to
Can't Post
Thanks for the math lesson. Your answer leaves out a lot of gearing in between. My question is about OVER cross-chaining.
Bell Head
Nov 6, 09 17:30
Post #4 of 14 (278 views)
In reply to
Can't Post
I usually try to avoid the two smallest cogs when in the small chainring and the two largest cogs when in the big chain ring. But I'll go one more if I'm racing and I think I only need to be in it for a short while.
Victor
armycyclist
Nov 6, 09 18:03
Post #5 of 14 (261 views)
Re: Cross-chaining? [Bell Head]
In reply to
Can't Post
In Reply To:
Victor
with today's index shifting. I don't get cross chaining.. the only time I do is when I'm riding my 12-28..and that's when I'm on the 52. Any other time I can run my 52/39 with my 12-25, my 11-23 or my 11-25 and not get any cross chaining.. I migh get a little rub on the 25.. but hardly notice it...
BUT if you're loosing 3 gears on each Chainring.. find a better wrench or learn how to adjust you RD & FD your self, it is really fairly easy to do..
Bell Head
Nov 6, 09 18:18
Post #6 of 14 (255 views)
Re: Cross-chaining? [armycyclist]
In reply to
Can't Post
I think you may have misunderstood me, or perhaps I explained it poorly.
I'm don't get any rub in any gear and I'm a perfectly good wrench myself; I do try to keep as straight chain line as possible.
I see no need to use small-small or large-large gearing, or even small-2nd smallest or large-2nd largest gearing except in rare situations, like popping over a short steep hill.
TrueGrit
Nov 6, 09 18:34
Post #7 of 14 (248 views)
In reply to
Can't Post
In Reply To:
Yes, that's what I was getting at. I'm just thinking the straighter the chain...the more optimal in general if you're gonna be there for 56 miles or so. I typically ride in the big ring but this particular course is flat and windy so staying in the small ring will allow me more subtle changes in gearing/resistance when adjusting the rear (even though I will be on the small side of the cassette). Thanks.
TrueGrit
Nov 6, 09 20:53
Post #8 of 14 (218 views)
In reply to
Can't Post
justfast
Nov 6, 09 21:42
Post #9 of 14 (207 views)
Re: Over Cross-Chaining? [TrueGrit]
In reply to
Can't Post
I was certain you had an overuse injury. =)
TrueGrit
Nov 7, 09 0:34
Post #10 of 14 (184 views)
Re: Over Cross-Chaining? [justfast]
In reply to
Can't Post
In Reply To:
kdw
Nov 7, 09 4:34
Post #11 of 14 (154 views)
In reply to
Can't Post
Too much weight lifting, rollerblading, xc skiing, etc.
JoeO
Nov 7, 09 8:16
Post #12 of 14 (127 views)
In reply to
Can't Post
I cross chain all the time.
armycyclist
Nov 7, 09 9:49
Post #13 of 14 (107 views)
In reply to
Can't Post
ok. so what cassette are you running... ON flat courses.. I run and 11-23; which give me 11, 12, 13, 14, 15, 16, 17, 19, 21, 23
verses a 12- 25 which I see a lot of folks riding give you.. 12, 13, 14, 15, 17, 19, 21, 23, 25
on the 12-25 you have a TWO tooth jump on half your gears, while the 11-23 only on the last three... I find it keeps the chain straighter.. and easier to find a good gear to spin on flat courses...
just my .02
sharprace
Nov 7, 09 15:11
Post #14 of 14 (78 views)
In reply to
Can't Post
I always thought that running big-big and small-small was too much cross chaining, but acceptable for short periods of time (short hills, etc) if changing the FD is going to considerably upset your position/power out put. I don't think that you do too much damage to your drive train with cross chaining since drivetrains are so robust now.
Print Thread
Your tri bike position
Your biggest need is more:
Comfort
Power
Aerodynamics
It's perfect
