Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Lori Bowden's Carbon X's
  Tri ForumClassifiedsLavender RoomJobsThe Womens
JP
Dec 23, 03 12:43
Post #1 of 21 (1932 views)
Lori Bowden's Carbon X's Can't Post
Hi all,
Recently while perusing the latest Triathlete mag I noticed a bike photo of Lori Bowden in this years Ironman Hawaii, I noticed that her armrests are mounted directly on the base bar of her Profile Carbon X's. I thought about doing this myself in the past as I find that I'm not quite low enough when in the aero position and there is a big height difference in my aero extensions and my armrests which usually leads to wrist pain during long rides. Before I try to mod these myself and potentially ruin a brand new set of Carbon X's has anyone else done this mod and can you share the details with me?
Thanks in advance
Jason
danb
Dec 23, 03 18:22
Post #2 of 21 (1783 views)
Re: Lori Bowden's Carbon X's [JP] [In reply to] Can't Post
I am modifying mine. Write me off list dan@orcasonline.com
Mike in CA
Dec 23, 03 21:47
Post #3 of 21 (1714 views)
I am interested in this as well, let me know if you figure it out.
Thanks,
Mike
Francois
Dec 23, 03 22:02
Post #4 of 21 (1709 views)
Re: Lori Bowden's Carbon X's [Mike in CA] [In reply to] Can't Post
I did it myself. really easy.
Get the metal piece between the pad and bar off.
Then enlarge slightly the hole of the pads where
you will get the screw through (not large enough otherwise).
Put a large washer on the base bar and tighten the pad directly on the base bar (don't forget the large washer of the carbon will crack).
it lowers the position quite a bit and makes the pads closer.
ckautz
Dec 23, 03 22:26
Post #5 of 21 (1699 views)
Re: Lori Bowden's Carbon X's [Francois] [In reply to] Can't Post
I have done exactly as you describe to a number of client bikes over the years - it's very easy and works really well.
Christopher Kautz, PK Cycling
www.pkcycling.com
sergio
Dec 24, 03 1:19
Post #6 of 21 (1675 views)
Re: Lori Bowden's Carbon X's [ckautz] [In reply to] Can't Post
I use the same bar tuning...
Add to the lower position a weight saving of about 150 grams which means that you will have a carbonx weighting 850 grams :-).
Not that it really matters for this case :-)
Sergio Marques
Sérgio Marques
When it hurts is when it feels good ;-)
Sergio-Marques.com
JP
Dec 30, 03 16:59
Post #7 of 21 (1440 views)
Re: Lori Bowden's Carbon X's [sergio] [In reply to] Can't Post
Thanks for the info...I will try this over the weekend, it might save me a few hundred bucks since I don't have to go out and buy the Hed bars now!! One question though, do you use the same bolts that are in the bars currently? If that is the case will they now stick out more though the bottom of the bar? I guess that's not an issue.
Thanks!!
sergio
Dec 31, 03 1:00
Post #8 of 21 (1362 views)
That wasn´t the problem for me, the bolts are fine and don´t stick out at least enough to get me wondering if i should cut the bolt (about 1mm).
Sergio Marques
Sérgio Marques
Sergio-Marques.com
amb18
Feb 23, 04 2:45
Post #9 of 21 (1207 views)
I hate to be dense- but I am also loking to perform this small operation- but I want to know exactly what I am doing- can you give more specic instructions? Pictures? Thanks
sergio
Feb 23, 04 4:14
Post #10 of 21 (1176 views)
Re: Lori Bowden's Carbon X's [amb18] [In reply to] Can't Post
send me an e-mail, i will reply with some photos. I think that me and Francois did the same operation on those bars.
Sérgio Marques
Sergio-Marques.com
(This post was edited by sergio on Feb 23, 04 4:15)
smartasscoach
Feb 23, 04 4:36
Post #11 of 21 (1148 views)
I seem to remember you didn't do it alone, you had some help of a well unknown aero guru ;-)
"Yeah, no one likes a smartass, but we all like stars" - Thom Yorke
smartasscoach.tri-oeiras.com
Topher
Feb 23, 04 5:17
Post #12 of 21 (1114 views)
I am interested in doing the Profile modification also. When I take everything apart and look at the holes on the pad piece, I notice that they are not wide enough apart to match with the base bar. It also looks like the pad piece starts to curve up where I might want to drill a new hole, which would not work. So ... Are you just enlarging the existing holes or making new ones on the pad?
sergio
Feb 23, 04 5:28
Post #13 of 21 (1099 views)
Re: Lori Bowden's Carbon X's [Topher] [In reply to] Can't Post
I have the pad fixed with only one bolt, the other stays below the the aluminium pad.
Enlarged the hole that I needed to fix the pad, a very simple process.
Sérgio Marques
Sergio-Marques.com
Francois
Feb 23, 04 6:17
Post #14 of 21 (1050 views)
1. remove the pads.
2. remove the metal piece between the base and the pads.
3. figure out the position you want for the pads
4. when you know the position, you need to enlarge the corresponding hole in the pads (there are 6 holes for but they are not large enough for the screw)
5. once the hole is large enough, put one washer over this hole, and a washer directly over the base then have the screw going through the two washers and the pad.
I am mechanically challenged and was able to do so...so anyone can do this.
following the Walser bar discussion, if you also need straight bars (a la Ullrich), remove the extensions, and replace them with a straight mountain bike bar cut in two with the par that normally goes in the stem attached to the base and put the bar end shifters inside the opposite part.
smartasscoach
Feb 23, 04 6:22
Post #15 of 21 (1042 views)
You mean straight bars a la Armstrong, don't you? ;-)
Francois
Feb 23, 04 6:24
Post #16 of 21 (1036 views)
Re: Lori Bowden's Carbon X's [smartasscoach] [In reply to] Can't Post
nope mate! he is just a copycat ;-)
actually I am fairly sure someone used straight bars before Ullrich as well...
john
Feb 23, 04 6:35
Post #17 of 21 (1024 views)
"actually I am fairly sure someone used straight bars before Ullrich as well... "
The Gerolsteiner posse has been using them for a while (Rich, Peschel, Totschnig, Rebellin, etc.). Thurig and Leder are other notable users.
I've been experimenting with straight bars myself this season and really like them so far. For me the key was to find elbow rests that can pivot forward (like the Dedas) rather than fixed rests (Jammer GT).
Topher
Feb 23, 04 8:27
Post #18 of 21 (946 views)
Does anyone have a picture of this setup to post?
Are you using carbon or aluminum mountain bike bars to cut?
GregX
Feb 23, 04 9:51
Post #19 of 21 (872 views)
Re: Lori Bowden's Carbon X's [john] [In reply to] Can't Post
What model of Dedas are you referring to in your post? Thanks.
"Half of what we taught you is wrong. Unfortunately, we do not know which half."
-- Dean and cardiologist C. S. Burwell to a Harvard Med School graduating class.
Where would you want to swim ?
john
Feb 23, 04 10:37
Post #20 of 21 (833 views)
Re: Lori Bowden's Carbon X's [Greg/ORD] [In reply to] Can't Post
These:
http://aebike.com/site/page.cfm?PageID=30&SKU=HB5946
Uncle Phil
Feb 28, 05 21:08
Post #21 of 21 (476 views)
Re: Lori Bowden's Carbon X's [In reply to] Can't Post
Anybdy still have photos of modified Carbon-X's? I am thinking of modifying some and would like to make sure I understand what they should look like afterwards. Thanks!
The Pro Effect
Which male pro is most likely to influence your buying decisions
Al Sultan
Alexander
Andersson
DeBoom
Frodeno
Gomez
Kemper
Lieto
Lovato
McCormack
Other
Potts
Rapp
Reid
Sindballe
Stadler
Whitfield
