Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Kalibur Rear Triangle After Crash
  Tri ForumClassifiedsLavender RoomThe Womens
allenpg
Jul 4, 08 14:14
Post #1 of 3 (182 views)
Kalibur Rear Triangle After Crash Can't Post
I finally got around to closely checking my Kuota Kalibur over for damage following my crash a month ago. I haven't noticed cracks at all, but I was a little surprised to see an offset in the rear triangle. There seems to be about a 5 mm difference between the DS and NDS. I don't recall seeing this before. I checked this with 2 perfectly dished wheels and it was the same for each one. Is this normal? I wouldn't be surprised to see this on an aluminum or steel frame after a crash, but carbon fiber doesn't bend [scratching head in confusion]. Anyway, I'm taking the frame to the LBS where I bought it to have them look it over. Thanks!
-Pete
http://www.extrememomentum.com
http://www.midwesttimetrial.com
swimfan
Jul 4, 08 14:18
Post #2 of 3 (173 views)
Re: Kalibur Rear Triangle After Crash [allenpg] [In reply to] Can't Post
Curse of the napoleon!
Problem could be on the wheel, check the horizantal screws if they are both at the same lenght then check the axle on the wheel.
_________________________________________________
To rent this space PM me!
Aus(Justin)tin
Jul 4, 08 14:21
Post #3 of 3 (164 views)
Re: Kalibur Rear Triangle After Crash [swimfan] [In reply to] Can't Post
Horizontal screws? The Kalibur has vertical dropouts.
Justin in Austin, get it? :)
Cool races:
- Redman
- Desoto American Triple T
