In Reply To:
So the recommendation when bogging down under too high a load is to go to a yet harder gear first before shifting the front, in order to avoid excessive spinning? It will avoid excessive spinning, but that's not worth it to me.
For me, shifting the front is a soft-pedal activity in order to make it go smoothly, and (maybe because it is) there is no problem with overspinning. Because the shift on the front requires a significant rotation on the cranks to complete, it will be over and done with faster if performed *before* shifting to a harder gear on the back. Higher leg rate during the shift means shift completed sooner which means back on the power quicker, which is important when going uphill in order not to lose too much speed.
Well not exactly, my suggestion was a strategy to avoid being bogged down in the first place, although I may have struggled to write it clearly.
What I meant to say was that as you gain experience you'll learn when an imminent shfit to the small ring is coming. By dropping to the small ring early/before you have to, and at the same time (or immediately before), quickly shifting a gear or two in the back, you can maintain virtually the exact same gear and pace. Now the front shift is done and as the grade continues to increase, you just keep moving to an easier gear in the rear as needed. My goal is to keep my momentum so I don't have to do a soft-pedal when the grade really gets steep.
Now I agree that whether you do the quick one/two gear shift in the back comes immediately before, immediately after or at the same time is irrelevant ad can be done according to personal preference, shifting performance or where on the climb you are. My point was that this allows you to maintiain roughly the same gear as you were in on the big ring.
I think for most people, this stuff all starts to come pretty naturally after enough time on the bike.
