Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Hey iPod people, few ???'s.
  Tri ForumClassifiedsLavender RoomJobsThe Womens
Martin C
Dec 5, 04 15:20
Post #1 of 9 (613 views)
Hey iPod people, few ???'s. Can't Post
Running iTunes, 400 songs so far. We have begun to download from Apple now that DSL is here.
Question...
Any bugs with having 'his and hers' iPod minis? Curious..if we have one giant library, which I manage, then the triwife manages her own playlists from MY library.....how will this work when we link two different iPods?
She won't want to download the main library (mine), but will want to work from HER library (playlist). Any thoughts before we send a tele to Santa?
LC
"It sucks for everyone after 150 miles." -Me-
(This post was edited by LarryCalifornia on Dec 5, 04 15:20)
lobo
Dec 5, 04 17:36
Post #2 of 9 (521 views)
Re: Hey iPod people, few ???'s. [LarryCalifornia] [In reply to] Can't Post
Larry,
You'll need to make separate playlists (see under the File Menu and they'll appear under source). Drag & drop your songs into your individual playlists. When you plug in the iPod, you'll see an iPod icon on the bottom right hand side – does NOT show up until you plug the iPod into the CPU. When that icon appears, click it, and you get options of when this iPod (mini, mega, his, hers, cats, dogs, etc) connects, download X,Y & Z playlist or Z & Y or just X, etc.
Good luck
John
Austin, TX
jcurtis
Dec 5, 04 17:53
Post #3 of 9 (504 views)
Set iTunes for manual, rather than automatic, updates. That way, you choose what is added and removed from your iPod(s). this also allows you to store more music on your computer than your mini will hold.
"In case of flood climb to safety"
Martin C
Dec 5, 04 18:24
Post #4 of 9 (481 views)
Re: Hey iPod people, few ???'s. [j-son] [In reply to] Can't Post
Right on, thanks. I just need to make sure you can designate what playlist you would like to download to iPod. The wife will be creating Playlists from the overall Library (mine), so I was hoping she could just download her managed Playlist, rather than from the Library. I guess I've heard the iPod automatically transfers the entire Library, which she will not want to do....
LC
ChiBri
Dec 5, 04 18:55
Post #5 of 9 (464 views)
I just bought his and hers minis as well and had the same problem. We log on as different users with Windows XP and I set it up so her music will load into her folder and my music will load onto my folder. The one drawback is that there will be some music that we have in both our folders but I bought an 80 gig USB hard drive specifically to store our music so I think we will have plenty of room. And if we do run out I'll just erase some of her music.
Uncle Phil
Dec 5, 04 19:37
Post #6 of 9 (439 views)
You can set the iPod/iPod minis to only download selected playlists rather than all the playlists. Select the iPod/iPod mini in iTunes and then click the "Display iPod options" button in the bottom right corner of the screen. It should be the left-most of the four buttons down there (looks like a iPod). Then make the appropriate buttonw selection under the "music" tab and check or un-check whatever playlists you want to have copied over. Only the music on those playlists will be copied into the iPod's memory.
Martin C
Dec 5, 04 21:15
Post #7 of 9 (402 views)
Re: Hey iPod people, few ???'s. [Uncle Phil] [In reply to] Can't Post
[reply] Select the iPod/iPod mini in iTunes and then click the "Display iPod options" button in the bottom right corner of the screen. It should be the left-most of the four buttons down there (looks like a iPod). Then make the appropriate buttonw selection under the "music" tab and check or un-check whatever playlists you want to have copied over. Only the music on those playlists will be copied into the iPod's memory.[/reply]
Right on. So I'm assuming when you link your iPod it isn't automatically transferring your music until you make this selection?
LC
Uncle Phil
Dec 5, 04 22:15
Post #8 of 9 (372 views)
WHen you connect an iPod or an iPod mini for the first time, I believe the default is to open iTunes and then transfer everything UNLESS the available memory is less than the size of the music library (like in your case). In that case I think it pops open a dialog telling you that there isn't enough memory to transfer everything and asks you what you want to do.
Hinds57
Jan 2, 05 19:24
Post #9 of 9 (224 views)
Uncle Phil, You Rock!
I just spent a few hours trying to figure out how to get my plylists on my mini. After I went over 4 gigs loaded into my PC my ipod mini went to one general playlist. A quick search found this thread and the solution.
Thanks
Dave
Off Season
What will you do in the off season?
Bike focus
MTB or 'cross
No training
Run focus
Swim focus
What offseason?
XC ski or snowshoe
