Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
HED C2 90 fit question
  Tri ForumClassifiedsLavender RoomJobsThe Womens
fatbastardtris
Oct 8, 08 17:57
Post #1 of 9 (480 views)
HED C2 90 fit question Can't Post
I contacted HED with this question but they didn't know the answer off hand. I'm considering getting a C2 90 rear wheel. I want to make sure that it will fit my road bike as well, a Scott CR1 Pro, with the wider width of that rim. HED said that they were having issues with the Scott Plasm fitting. Anyone know whether this wheel will fit into the CR1 Pro without scrubbing?
WillPA
Oct 8, 08 18:18
Post #2 of 9 (461 views)
Re: HED C2 90 fit question [fatbastardtris] [In reply to] Can't Post
Ask HED about the 'skinny' option. They were really helpful when my Jet C2 didn't fit on my Argon...
fatbastardtris
Oct 8, 08 18:25
Post #3 of 9 (449 views)
Re: HED C2 90 fit question [WillPA] [In reply to] Can't Post
I did but I was hoping that the CR1 Pro might not need that. If it doesn't then I can just get the standard build which I prefer. I just need to find out if it will fit or not.
slidecontrol
Oct 8, 08 18:44
Post #4 of 9 (422 views)
I cannot be of any help yet, but if anyone knows how wide the wide point is on a Jet C2-90 and how far out from the axle it extends, I can measure my plasma (L) and my friends CR1 (M) and post up the numbers. That should hopefully be of some use. to someone. ( I see the OP already has a CR1, )
i reject your reality and substitute my own
Adam Savage
Guns don't kill people... Quick releases kill people
WillPA
Oct 8, 08 19:24
Post #5 of 9 (401 views)
Re: HED C2 90 fit question [slidecontrol] [In reply to] Can't Post
Widest on mine was 32mm, probably a 6 - 7 cm in from the rim, not sure about that, but I measured the width with calipers. Widest clearance of my chainstay...you guessed it, 32mm...
Do a search, I think the guys from HED have posted some of the frames known to be problematic with the C2s...
Andrew69
Oct 9, 08 0:23
Post #6 of 9 (348 views)
I have found that the biggest problem with the C2 90 is not so much the overall width, but the variabliity of the width. The fairing varies in width around its circumference so you can set the wheel up so that it clears the chain stays, rotate the wheel 90 or 180 degrees, and the fairing will touch the chain stays again!
My C2 60 does not suffer from the problem at all.
Very , very frustrating and disappointing for the money I paid for it.
WillPA
Oct 9, 08 5:56
Post #7 of 9 (292 views)
Re: HED C2 90 fit question [Andrew69] [In reply to] Can't Post
You really contact HED, I had the same problem and they were extremely helpful and pleasant to deal with. My wheel is now perfect and I'm very happy.
fatbastardtris
Oct 9, 08 7:07
Post #8 of 9 (265 views)
Can you tell or show me where to measure my CR1 Pro and I'll get the measurement (mine is size 51 I believe). The guy at HED said that I could take a photo and send it to him and he could tell me but I can't seem to find my camera.
slidecontrol
Oct 9, 08 13:56
Post #9 of 9 (172 views)
WILLPA measured his jet as being widest between 6 and 7cm back from the rim , but a normal wheel in your frame, and measure a similar distance inwards in a straightline to the axle , ( mark a convienent spoke to recall the distance.) then rotate the wheel so the mark lines up with the chainstay. That will be the point to measure the chainstay gap. there will probably only be a very small variation between the frame sizes since the BBs are all the same width and the same size wheel is used as well.
Adam Savage
Off Season
What will you do in the off season?
Bike focus
MTB or 'cross
No training
Run focus
Swim focus
What offseason?
XC ski or snowshoe
