Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Does this bar setup create an aerodynamic DISadvantage?
First page Previous page 1 2 Next page Last page  View All Tri ForumClassifiedsLavender RoomJobsThe Womens
ride2eat
Nov 6, 09 16:57
Post #1 of 42 (2372 views)
Does this bar setup create an aerodynamic DISadvantage? Can't Post
In an effort to take the bend out of my T2's and get them flat, i turned them sideways or inwards rather. The net effect of that did flatten the bar ends, but it puts my hands closer together. In an unexpected 'twist' it actually turned out to be incredibly comfortable as my two hands basically turned into one.....they join figers sort of. My elbows are virtually in the same position, but does this create any kind of a DISadvantage? If it's an advantage that is fine and bonus time, but I don't want to do it if it's creating a disadvantage.
hgrong
Nov 6, 09 17:01
Post #2 of 42 (2357 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [ride2eat] [In reply to] Can't Post
The difference, if there is one, is probably impossible to predict without a wind tunnel (or a lot of free time, a PM, and patience for the same loop of road).
I say, if it is comfortable, go with it.
(This post was edited by hgrong on Nov 6, 09 17:02)
draketriathlon
Nov 6, 09 17:02
Post #3 of 42 (2356 views)
In Reply To:
The tunnel knows... no one else here does...
cbritri
Nov 6, 09 17:09
Post #4 of 42 (2333 views)
I agree with what others have said so far, but Dave Zabreski (sp?) has a similar hand position.
Tom A.
Nov 6, 09 17:58
Post #5 of 42 (2278 views)
If anything, I would think it would have lower drag...that's how I used to run my T2+ bars as well...but, with them also tilted up a fair amount ;-)
John Cobb
Nov 6, 09 18:21
Post #6 of 42 (2247 views)
The aero difference will be small but I would think better. This is nothing compared to the bad aero from you brake levers sitting straight into the wind.
New Blog - www.johncobbresearch.com
ride2eat
Nov 6, 09 18:24
Post #7 of 42 (2237 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [John Cobb] [In reply to] Can't Post
Holy smokes I got a comment from John Cobb....my week is made!
Your saddle is.....shall we say......UNBELIEVABLE.....thank you!
As my comment will attest to my lack of tweaking knowledge....how do I get my 'brake air dam' out of the wind.....cut the bar ends maybe to get them pointed down? I have no idea....thanks for any further advice.
jackmott
Nov 6, 09 19:01
Post #8 of 42 (2183 views)
someone on here who has spent time in the wind tunnel said cutting the upturns on the visions isn't worth the time
but that is assuming you are using the vision brakes
which, would get most of your brake air dam out of the wind anyway =)
In Reply To:
What is good in life? - To crush your enemie's dreams, see them dropped behind you, and to hear the lamentation of their women!
Sunglasses: http://www.framesdirect.com/sunglasses
Tri Gear: http://www.atctrishop.com
Cheap Disc Wheel - http://www.wheelbuilder.com Tire Crr Data - http://www.biketechreview.com
BMAN
Nov 6, 09 19:57
Post #9 of 42 (2114 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [jackmott] [In reply to] Can't Post
That is why my Vision basebar/Hed aerobar set up will be getting some new Vision levers very soon. Not the most high end set up but I would put is as one of the most aero set-ups that you can get and for not very much money. My HED/Vision aerobar set up only ran me $140 complete and everything was new. Now that is aero on a budget.
Aero & Light is Right
SLC 2.0
Bell Head
Nov 6, 09 20:22
Post #10 of 42 (2086 views)
In Reply To:
Interesting, because I have the same base bar/brake setup. I've long thought of getting the vision brake levers, but they look more dangerous than an unplugged bar end.
I figure, I can keep in the Cane Creek levers for training, but swap in the Vision levers for races.
ride2eat
Nov 7, 09 5:03
Post #11 of 42 (1931 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [BMAN] [In reply to] Can't Post
Is it that the end of the Vision base bar is turned up that makes it less aero or the actual brake lever. Having never touched the Vision lever I can't say, but looking at it I feel as though it would stick up as well? Guess I would have to see it mounted to know.
JoeO
Nov 7, 09 8:12
Post #12 of 42 (1805 views)
If that's more comfortable for you, that's good. You should probably stick with it. But you didn't really take the bend out (aerodynamically speaking) in any way that I can see. You just moved it from the vertical plane to the horizontal one.
The_Mickstar
Nov 7, 09 13:58
Post #13 of 42 (1669 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [JoeO] [In reply to] Can't Post
I think he meant that he took the rise out of the extensions (to lower his hands).
Steve
Cervélo Mafia
member since June 2006
Ryon
Nov 7, 09 15:13
Post #14 of 42 (1611 views)
I used to race with my hands right together in a similar setup to that.
What I found is that, if I actually have my hands a little apart it causes my shoulders to rotate inward and makes it easier to "scrunch" my shoulders and keep my head lower:
Granted, this is highly personal, but it's worth looking at.
My Science Blog: LC Giraffe
What Would Jens Do?
sharprace
Nov 7, 09 15:53
Post #15 of 42 (1566 views)
I think that comfort would be paramount to the slight change in aerodynamics that it would make. If you're more comfortable, you're able to go harder... so you'll be faster!!
paddy-o
Nov 7, 09 16:49
Post #16 of 42 (1528 views)
I remember seeing in the late 90's, at Ironman Canada, a number of Japanese athletes whose aerobars consisted of only one bar, i.e. both hands were wrapped around the same bar. Weird looking, for sure.
1406racer
Nov 7, 09 17:11
Post #17 of 42 (1507 views)
In Reply To:
Dynamic Du
Nov 7, 09 19:23
Post #18 of 42 (1452 views)
In Reply To:
I'm seeking clarification on this comment. Are you saying (or does anybody else have an interpretation) that the aerobars with the "hood" sections upturned where the break levers are attached are not as aerodynamic as the ones that extend straight out??
Most companies have a bend in the wide/hood extension section that points up in the air, I don't like it but it's hard to get a set without it.
John Cobb
Nov 7, 09 19:42
Post #19 of 42 (1434 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [Dynamic Du] [In reply to] Can't Post
I believe that the upturned bars are not as efficient but riders generally like to have the feel so when stopping your hands don't slip off. I suppose you would want some numbers so I looked up some, doing a test with base bars mounted on a 56 kinda' aero [2004] frame with parts on it. B/R is Blackwell Research carbon levers
Drag with upturned ends, B/R levers - 1249gr. @ 0 yaw
Upturned ends , Vision levers - 1192gr @ 0 yaw
Flat ends w/ B/R levers flat - 1155 gr. @ 0 yaw
I believe you can cut most of the current bars if desired.
Dynamic Du
Nov 7, 09 20:01
Post #20 of 42 (1416 views)
In Reply To:
Thanks so much Mr Cobb. This stuff is gold. I'm cutting my bars for comfort (don't like the upturned ends) but now I'm even more interested in cutting them.
From my calculations from stuff Coggan posted a few days ago about grams of drag converted to seconds ( 0.1 lbs (50 g) of drag (at 30 mph) = 0.5 s/km = 5 W = 0.005 m^2 CdA = 0.0005 Crr that would appear that the 94 grams of drag (possibly more if you have Vision levers wich I have) saved over say a 40km course would be around 40 seconds saved IF at zero yaw. I would imagine higher yaw angles would lesson this, but even so, it is basically certain to be faster.
now where's that hacksaw......
moneydog59
Nov 8, 09 4:03
Post #21 of 42 (1347 views)
use a piper cutter, it will give you a cleaner cut...
"one eye doubles my eyesight, so things don't look half bad" John Hiatt
Tom A.
Nov 8, 09 6:54
Post #22 of 42 (1279 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [moneydog59] [In reply to] Can't Post
In Reply To:
With a pipe cutter, it's hard to get as close as possible to the bend. I prefer to just pop a hose clamp on there and use it as a cutting guide for either a hacksaw or a dremel.
Just make sure you cut on the right side of the hose clamp!...don't ask why I emphasize that :-(
jeremyb
Nov 8, 09 7:05
Post #23 of 42 (1259 views)
Re: Does this bar setup create an aerodynamic DISadvantage? [Ryon] [In reply to] Can't Post
In Reply To:
The only difference here is the hand positions? No elbow width or pad height, etc?
Pretty crazy, thanks.
Plus One Lap Cyclocross ||| JeremyBurlingame.com
BMAN
Nov 8, 09 7:17
Post #24 of 42 (1247 views)
I would say use a cutting guide and a hacksaw. I have a Park cutting guide that I use to cut everything nice and square. Works fantasic on aerobar extensions and basebars.
SLC 2.0
jeremyb
Nov 8, 09 8:31
Post #25 of 42 (1187 views)
In Reply To:
Yep, agree with both Tom and Bman. I've used a Park steering tube cutting guide and it works great-----can get much closer to the bend that with a pipe cutter, and it leaves a clean straight cut.
Are equipment rules important?
What organization's rules do you seek to comply with before you purchase bikes, wetsuits, etc.?
UCI
USA Cycling
UCI/USAC
WTC
USAT
WTC/USAT
ITU
All
None
