Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Dia Compe 188 rattle
  Tri ForumClassifiedsLavender RoomJobsThe Womens
Mike Hollywood
May 21, 03 11:38
Post #1 of 4 (111 views)
Dia Compe 188 rattle Can't Post
So I finally re-assembled my road bike and took it out for a ride today in the somewhat soggy northeast.
I had not noticed how much noise my brake levers on my tri bike were causing until today... the rattling is almost like white noise - I did not notice it until it was gone...
I've heard lots of other folks complain about loose/rattling dia compe 188's - does anyone have a fix or some way to keep the unnecessary noise to a minimum?
Woody
Mike Hollywood
http://www.bostontriathlonteam.com
http://www.michaelhollywood.com
david
May 21, 03 12:35
Post #2 of 4 (101 views)
Re: Dia Compe 188 rattle [Woody] [In reply to] Can't Post
The problem I have found is in the rivet. Either drill out the rivet and replace it w/ a quality bolt and washer; or, get a very, very thin nylon washer, cut out a pie slice, and slide it down in where the rivet is to tighten it up and stop the rattle.
Good Luck,
David
Be satisfied with your very best, Never give up, Do unto others.... http://www.squidoo.com/daviddaggett/ (Includes My IM Blog ) http://www.lewisdaggett.com
R Isgrigg
May 21, 03 12:53
Post #3 of 4 (91 views)
I think I remember Dan saying, that when he owned QR, they squeezed the rivet on every 188, with a pair of vice-grips or channel lock pliers, before they were shipped out, to eliminate the rattle.
Richard
TriBriGuy
May 21, 03 13:10
Post #4 of 4 (83 views)
While I'm loathe to suggest spending more $$ on your bike, I think any of the competing lever upgrades is well worth the $$. I rode rattling 188s for years, trying every trick in the book to silence them. Nothing worked 100%. I put Syntace Space Control levers on my newest bike and have been riding in blissful silence ever since. FWIW, the vise-grip pliers is the best solution outside of drilling out the pin and replacing it with bolt and bushing. Space Controls will run you about $80. I think the new Profile QuickStop 2s are slightly cheaper and have an added plus with a return spring.
AmZof Lemming
