Calendar
Retailers
Stack & Reach
Custom Geometry Calculator (beta)
More To Come...
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
Cutting Hed S Bends
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
Fast&Crooked
Oct 3, 08 17:17
Post #1 of 12 (212 views)
Cutting Hed S Bends
Can't Post
I just got a pair of Hed S Bends that are a bit too long at both ends. I guess I have a short forearm.
Can I cut them?
How do I cut them? Hack Saw?
Thanks...
cslone
Oct 3, 08 17:23
Post #2 of 12 (204 views)
Re: Cutting Hed S Bends [Fast&Crooked]
In reply to
Can't Post
A fine tooth hacksaw would work. I used a Dremel that worked great too.
______________
HEDmafia.com
Rokko
Oct 3, 08 17:25
Post #3 of 12 (200 views)
In reply to
Can't Post
I think you can only cut the end that goes into the clamps. The other end is reinforced for the bar end shifters, and you don't want to cut that off. That said, here's how to do it:
1) Measure carefully
2) Wrap the area of the cut in tape -- this helps keep splitting and dust down, and prevents scratches.
3) Use a guide.... I got a 10 cent pipe clamp and put it around the bar (over the tape), and used it for my guide
4) Measure again
5) Use a 32 tooth hacksaw
6) Probably should measure once more
7) Using the clamp as a guide, slowly saw about 2/3 to 3/4 of the way through (use minimal pressure on the saw)
8) Turn the bars, and cut from the other side to meet the first cut (this will also help prevent splitting)
9) The end can be filed smooth.
It's a pretty easy job... just nerve wracking the first time I cut into an $80 carbon bar
Blazeman Warrior
Wildflower Long, Big Kahuna, maybe Vineman, hopefully Alcatraz
James
Oct 3, 08 17:54
Post #4 of 12 (185 views)
In reply to
Can't Post
You can also cut the end where the shifters are. Jagwire makes a mount for shimano and sram shifters that are clamp style instead of plug. I had cut off mine at both ends also. I didn't know about the Jagwire mounts, so I just took the end of the compression plugs to the grinder until they fit. They've work like a charm for 4 years and counting.
Fast&Crooked
Oct 3, 08 17:58
Post #5 of 12 (181 views)
Re: Cutting Hed S Bends [James]
In reply to
Can't Post
Why the heck did they make it so long after the S bend! What a pain :(
Diesel
Oct 3, 08 18:08
Post #6 of 12 (172 views)
In reply to
Can't Post
WEAR A MASK!!!!!!!!!!!!!!!
If you don't you'll surely be responding to my post afterwards.
1406racer
Oct 3, 08 18:12
Post #7 of 12 (169 views)
In reply to
Can't Post
Have at it and cut off as much as you need from either end. Hed has assured me that it is not a problem. In fact the s bends that I have from them have no reinforcement at either end. Just do not tighten the shifter mounts too tight and split the tube. I ran mine for several years without any issues.
Fast&Crooked
Oct 7, 08 9:39
Post #8 of 12 (124 views)
Re: Cutting Hed S Bends [1406racer]
In reply to
Can't Post
Well mine had reinforcements... As in past tense because I can not slide the bar end shifter back in because it hits the reinforcement... I guess I am stuck with the jagwire thingy or this was an expensive lesson!
(This post was
edited
by Fast&Crooked on Oct 7, 08 9:40)
MOP_Mike
Oct 7, 08 9:44
Post #9 of 12 (119 views)
In reply to
Can't Post
Fine-tooth hacksaw, miter box, and a couple of clamps work fine.
Like others said, beware of cutting the shifter end.
On HED's aluminum standard 'S' bend, I cut the shifter end and there was not enough straight tubing left for the shifter to fit inside. (Yep, ruined!)
I replaced my ruined bars with a set of carbon "lazy S" bars. These have a longer straight section at the shifter end and can be cut back an inch or so at that end and as much as you want at the basebar end.
"...if you are pedaling correctly, it doesn't matter what cranks are on your bike." -- Frank Day
Rokko
Oct 7, 08 10:21
Post #10 of 12 (100 views)
In reply to
Can't Post
I have a set of carbon Hed S-Bends that I have cut, but don't use. I found the angle of the S-Bend too dramatic for my wrists. They are about 7 5/8" horizontal (roughly 192mm +-). Perfect condition other than one scratch on each from where the clamp held them. Only cut the clamp end, not the shifter end. I have a camera somewhere, but I can't find it right now. PM me if you have any interest.
Blazeman Warrior
Fast&Crooked
Oct 7, 08 10:33
Post #11 of 12 (92 views)
Re: Cutting Hed S Bends [Rokko]
In reply to
Can't Post
Problem is I need them cut from bot ends or I hit the S bend in the wrong place... I can't reach the shifters.
Thanks for the offer. Do the other brand S bends fit the Hed base bar?
Rokko
Oct 7, 08 13:19
Post #12 of 12 (63 views)
In reply to
Can't Post
They should. Most extensions are a fairly stanard size.... I think 21.8mm or something like that. So Hed, Profile Design, I think Oval should all work. I fit Blackwell Research Wrist Relief's into my Hed base bar. The BR's are slightly bigger (22.1mm?), but they still fit. It's just a snug fit.
Print Thread
Off Season
What will you do in the off season?
Bike focus
MTB or 'cross
No training
Run focus
Swim focus
What offseason?
XC ski or snowshoe
