Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Crank length article in triathlete mag ?
First page Previous page 1 2 3 Next page Last page  View All Tri ForumClassifiedsLavender RoomJobsThe Womens
xtrpickels
Oct 8, 08 22:34
Post #51 of 71 (768 views)
Re: Crank length article in Triathlete mag ? [Joe Santos] [In reply to] Can't Post
In Reply To
I think I'm remembering right. Isn't there a Martin paper that tests a decent sample size of athletes over quite a large range of crank lengths? I want to say it was a huge length range, from something around 120mm to 220mm. Pretty sure he presented this data at a seminar at the Serotta Symposium earlier this year. The interesting thing being, I believe he found the data to suggest the most efficient crank length was around 140mm (not remembering for what size rider). Anybody else seen/remember this paper?
Jim, sorry if any of this is incorrect. This is just off memory and I haven't gone back to re-read yet.
_______________________________
-Joe S.
  He and I were talking after that and he said that he personally would use the shortest allowable cranks, especially in crit's.
Now, as someone mentioned earlier and what i don't remember, the things that he held constant are important facts. Just because his one paper said short = good doesn't mean it is, certainly not for the whole population
Lactate Threshold Testing- Adirondack Medical Center- Lake Placid, NY
PM me if you would like information
www.amccares.org
rik
Oct 9, 08 1:56
Post #52 of 71 (737 views)
Re: Crank length article in triathlete mag ? [BikingJamin] [In reply to] Can't Post
In Reply To
I guess I may have had my 54 tooth on that day maybe even my 53 - Use your little internet Calculator and you tell me - was it the 53 or 54 :)
I apologize I took your post at face value. Forgot to adjust for the Slowtwitch Exaggeration Factor® - my mistake.
Seriously, I would love to know how you are squeezing that much speed out of 360 watts. 360 watts only gets me around 28.5 mph or so.
More on topic: this is the VeloNews summary of the Serotta Science of Cycling Symposium at which Jim Martin presented his findings on crank length:
http://www.velonews.com/article/71634
Quote
His studies of 16 bike racers of various heights doing maximal sprint power tests of under four seconds duration on cranks of 120, 145, 170, 195, and 220mm showed no statistical difference between crank lengths. Seat height to the pedal was maintained throughout, but fore-aft saddle position and handlebar height were not readjusted with crank length changes, despite variations with crank length of pedal-to-knee relationship and saddle-to-bar drop. This also led to Martin’s assertion that he could see no point to positioning the knee over the pedal spindle.
Also see this: http://boulderreport.bicycling.com/...blinded-by-scie.html
Quote
-Crank length matters: Not so, says Martin, who did research showing that maximum power varies by, at most, a few percent depending on crank lengths. And we're not talking about the difference between 170mm and 172.5mm either - Martin experimented with fulcrums as short as 120mm and as long as 220mm. Between 145mm cranks and 195mm cranks, maximum power output across all riders, short and tall, varied by a total of 1.6 percent. He did say he prefers 165mm arms for time-trialing, simply because they allow a rider to get lower on the bike, which is more aerodynamic, while preserving a good hip angle, which is essential for power production, which apparently isn't compromised by shorter crankarms.
Rik
GregX
Oct 9, 08 4:43
Post #53 of 71 (716 views)
Re: Crank length article in triathlete mag ? [rik] [In reply to] Can't Post
i have no doubt of Dr. Martin's competence. but a few things puzzle me:
In Reply To
  well, "a few percent" is a pretty big margin when you are aiming to win, and are concerned with the aerodynamics of brakes, cables, and aerobars.
In Reply To
  this is even more puzzling. don't shorter cranks force you to raise the seat height (assuming the same bike frame) ? ...
"Half of what we taught you is wrong. Unfortunately, we do not know which half."
-- Dean and cardiologist C. S. Burwell to a Harvard Med School graduating class.
Where would you want to swim ?
KT-tri
Oct 9, 08 5:55
Post #54 of 71 (690 views)
Re: Crank length article in Triathlete mag ? [John Cobb] [In reply to] Can't Post
well, I'm 5'3"....what should I be using then?
Tiger for Life -- War Eagle!
brandonecpt
Oct 9, 08 6:30
Post #55 of 71 (674 views)
Re: Crank length article in triathlete mag ? [GregX] [In reply to] Can't Post
In Reply To
But with the shorter cranks and higher seat, can't you potentially lower your bars since you'll have a more obtuse hip angle? Not arguing, just asking.
"Lemond is cycling's version of Rev Jessie Jackson." -johnnyperu 5/18/07
"Just because I suck doesn't mean my bike has to" -rickn 9/2/08
Joe Santos
Oct 9, 08 7:56
Post #56 of 71 (638 views)
Re: Crank length article in triathlete mag ? [brandonecpt] [In reply to] Can't Post
That's the more aero argument. Shorter crank allows for a slightly lower position while conserving hip angle at top dead center.
________________________________
-Joe S.
Davis Wheelworks
http://www.daviswheelworks.com
Davis, CA
The NorCal Tri, TT and Road Source For: Cervelo, Felt, Kuota, Scott, Cannondale, Look, Pinarello, Colnago, Time, Ridley, Seven. Zipp, Mavic, HED. Profile, X-Lab, Hydrotail.
GregX
Oct 9, 08 8:30
Post #57 of 71 (621 views)
Re: Crank length article in triathlete mag ? [Joe Santos] [In reply to] Can't Post
again, i don't get it. if my bike now has 175s, and i switch them our with some 165s, you're saying i should lower my seat ??
wouldn't i be raising my seat ??
what am i missing here? think about the knee angle at bottom dead center.
jaretj
Oct 9, 08 8:51
Post #58 of 71 (610 views)
If you are using a shorter crank your leg won't come up as far on the upstroke even if you adjust your seat so your knee angle at BDC is the same as before.
Your hip angle will be open more than before. You could then lower your bars/pads to get more aero while still having the same hip angle as you would with the longer cranks.
But then again we are looking at 5 to 10mm
jaretj
http://jaretj.blogspot.com
GregX
Oct 9, 08 8:55
Post #59 of 71 (606 views)
Re: Crank length article in triathlete mag ? [jaretj] [In reply to] Can't Post
In Reply To
  i understand what you are saying, but your hip angle won't change at all relative to the extended leg.
Tom A.
Oct 9, 08 8:57
Post #60 of 71 (601 views)
In Reply To
You guys are getting caught up in confusion of the definition of "lower". When you say "lower" you mean lower relative to the bike...while, I believe Joe means lowering just the torso when he says "lower".
Let me explain...no, that would take too long...let me sum up:
Shorter cranks on a given bike would require RAISING of the seat height to maintain knee extension angle (thus raising the entire body relative to the bike) while also allowing for a lower angle of the torso relative to the legs since there would be more "clearance" at the top of the stroke. Since there's more to be "gained" aerodynamically by lowering the torso angle than is "lost" (if anything) by raising the entire body relative to the bike, it's a net gain since the difference in leverage can be accomodated with gearing changes.
A side benefit for those encumbered by UCI requirements is that the raising of the seat and shifting it back (to accomodate keeping the knee in the same spot relative to the pedal spindle at the start of the power stroke) when implementing shorter cranks will also make it slightly easier to meet both the 5cm saddle offset and the limits on extension lengths since the body is effectively shifted rearward relative to the BB.
(This post was edited by Tom A. on Oct 9, 08 8:58)
rmur
Oct 9, 08 9:03
Post #61 of 71 (590 views)
Re: Crank length article in triathlete mag ? [Tom A.] [In reply to] Can't Post
Quote
you know, I was thinking the very same thing last night whilst doing some filler L3 in the aero position on the CT. Every few mm helps when we're dealing with X-Y limits ...
I wonder whatever happened to the 'angular' UCI rule discussions several months ago - re the Harp rig etc etc?
_________________________________
Gizmo marketing specialist :-)
brandonecpt
Oct 9, 08 9:37
Post #62 of 71 (570 views)
In Reply To
In Reply To
Right, but when your pedal is at 12 o'clock you'll have a more open hip angle allowing you to lower your bars. This COULD lead to a flatter back and a lower front end while keeping the same knee angle at extension and the same hip angle at 12 o'clock. No?
Don't ONLY think about the knee position and BDC, think about the hip at TDC
NavT
Oct 27, 08 12:24
Post #63 of 71 (393 views)
I'm 6'1" with long legs - I've been riding 172.5/175s since I started riding. Building up a tri bike and I have 170's. Can't hurt to give them a try - right?
sweddy
Oct 28, 08 9:59
Post #64 of 71 (323 views)
Interesting. It kind of implies that we each have a power band, just like a car engine, that has the most power between certain degrees of flexion. For example when your leg is almost straight the power you can deliver is less than if it's bent more, and if you're knee is at right angles the leg similarly is less powerful than when it's a little more open.
A shorter crank arm would do a better job of keeping you in your power band. Wouldn't make much difference for someone whose leg can deliver the same energy at any angle between top and bottom of a pedal stroke.
Apologies if this was already raised as I didn't read all the posts in the thread, sorry.
GregX
Oct 28, 08 10:07
Post #65 of 71 (315 views)
Re: Crank length article in triathlete mag ? [sweddy] [In reply to] Can't Post
In Reply To
personally, my common sense says that a proportional c
rank arm would do a better job of keeping you in your power band. because people vary a lot in size, it seems really improbable that one size fits all.
sweddy
Oct 28, 08 10:23
Post #66 of 71 (299 views)
Yes, that would also seem to be true. The point is that there seems to be a power band of knee angles that enables a rider to push harder than other angles. I believe it's also the basis for those oval cranks you can get, whatever they're called :-)
The proportional crank theory, although having intuitive benefits, seems to be what the OP was disproving with his sample size of 1.
geoffreydean
Oct 28, 08 10:44
Post #67 of 71 (281 views)
I think he should have said - lower your profile or front end of the bike - shorter crank arms allow you to go lower in the front end of the bike
Geoff from Indy
http://www.chandlervideo.com
http://www.indywebcast.com
jackmott
Oct 28, 08 10:53
Post #68 of 71 (266 views)
But I can tell another plausible story
that the long crack, distributes the load across a larger group of muscles thus improving endurance even as it hurts peak power
perhaps all judgement should be reserved until you test it.
In Reply To
dnp72178
Oct 28, 08 10:55
Post #69 of 71 (265 views)
Interesting stuff! Great thread! I am 6'7" (almost a foot taller than the normal triathlete!!) and just got fit from David Greenfield at Elite on a new Elite Razor Tri Bike. Props to him and his staff for an excellent job, the reputation of being the best in customer service was right on! I presonally didn't pay attention to crank size when getting fit, but after work today I'll measure and post the crank size on my new bike. It will provide some insight from a VERY tall triathlete's perspective!
Dan
sweddy
Oct 28, 08 11:17
Post #70 of 71 (247 views)
Re: Crank length article in triathlete mag ? [jackmott] [In reply to] Can't Post
I'm actually not agreeing or disagreeing with the short crank idea. Just trying to understand why the OP was seeing a positive result for short cranks with a tall rider.
I'm on whatever stock crank came with my Cervelo Dual, and I've got a lot more training to do before I need to think about crank length. I like the long crank distributing load across a larger group of muscles idea but I'm not sure I believe it. Isn't it just the same group just stretched/contracted more?
Bottom line is you're right: Once your pedalling technique is good you pretty much have to try out different crank lengths with a power meter to see if it's worth changing. But how would you be able to test for endurance? If you've trained with one crank length wouldn't you be naturally inclined to favour that length in long comparison rides since your muscles aren't used to the range of motion associated with the new crank?
jackmott
Oct 28, 08 11:22
Post #71 of 71 (241 views)
If testing for yourself, I imagine youd have to do a few long or medium term tests.
you could compare power to heart rate over some set distance or something
my guess is the differences are pretty small and would thus be really hard to measure accurately on your own.
which also means it doesn't really matter fortunately =)
In Reply To
The Pro Effect
Which male pro is most likely to influence your buying decisions
Al Sultan
Alexander
Andersson
DeBoom
Frodeno
Gomez
Kemper
Lieto
Lovato
McCormack
Other
Potts
Rapp
Reid
Sindballe
Stadler
Whitfield
