Bike Shops
Coaches
Fitters
Race Calendar
*NEW* Running Stores
Stack & Reach
Training Log
Triathlon Clubs
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
"Crack Pipe" Adapter
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
sgoehner
Jul 3, 08 19:13
Post #1 of 8 (352 views)
Can't Post
I need to pick one of these up as I just bought a disc cover and a set of HED 3's. None of my LBS's have them in stock and 2 of the 3 have suppliers that do not have them. Where can I find them online as I need to get one by next weekend?
Thanks in advance.
Dbeitel
Jul 3, 08 19:18
Post #2 of 8 (349 views)
Re: "Crack Pipe" Adapter [sgoehner]
In reply to
Can't Post
Try this:
http://www.competitivecyclist.com/...el-1134_47_TRUE.html
DB
show pony
Jul 3, 08 19:39
Post #3 of 8 (332 views)
In reply to
Can't Post
You might not need a crack pipe...they're bloody awful to use.
FWIW I run that exact set-up (H3 front, disc cover rear) and my Topeak Joe-Blow pump head fits both cavities fine, albeit with a suitable valve length. Do a search here as its been discussed many times...
What sort of pump do you have?
blood, sweat...and big gears
I hated every minute of training, but I said, ''Don't quit. Suffer now and live the rest of your life as a champion.''
- Muhammad Ali
sgoehner
Jul 3, 08 20:06
Post #4 of 8 (311 views)
Re: "Crack Pipe" Adapter [show pony]
In reply to
Can't Post
I have tried my pump and it does not fit in the opening. I have a Bontrager pump, so I have used a friends "pipe" and it wasn't too bad, but my pump just won't work.
show pony
Jul 3, 08 20:17
Post #5 of 8 (305 views)
In reply to
Can't Post
Gotcha. I'm under the impression you might be able to change the pump head (and tube, and other bits) to a Joe-Blow. There have been threads on this within the last few weeks...
http://forum.slowtwitch.com/...=joe%20blow;#1863431
http://forum.slowtwitch.com/...=joe%20blow;#1845954
...amongst others.
Have you used a crackpipe before?
I only suggest the above as trying to inflate tyres using the crack-pipe by yourself is a PITA...definitely doable, but a pain nonetheless. Might cost you a little more but save you a heap of frustration. If you always have company to help, then no big biggie....
- Muhammad Ali
Pickles
Jul 4, 08 7:52
Post #6 of 8 (223 views)
In reply to
Can't Post
What about a pump for when you flat during a race. Or will I still need a crack pipe for that?
Fast&Crooked
Jul 4, 08 8:06
Post #7 of 8 (208 views)
Re: "Crack Pipe" Adapter [Pickles]
In reply to
Can't Post
auto-inflator heads are usually small enough, so there is no need for a crack pipe...
Orcaman
Jul 4, 08 9:09
Post #8 of 8 (187 views)
In reply to
Can't Post
On my Hed 3's I have longer valves and then just attach a valve extender which enables me to use my regular pump head.
Member of the Litespeed Factory Team
www.litespeed.com
Print Thread
Are equipment rules important?
What organization's rules do you seek to comply with before you purchase bikes, wetsuits, etc.?
UCI
USA Cycling
UCI/USAC
WTC
USAT
WTC/USAT
ITU
All
None
