Calendar
Retailers
Stack & Reach
Custom Geometry Calculator
Online Training Log
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
Cleaning the BB
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
Occam's Razor
Nov 21, 08 16:40
Post #1 of 10 (263 views)
Cleaning the BB
Can't Post
So my road bike has developed this really annoying clicking sound lately. It only clicks when I am pedaling, and only if I add force to the pedals. If I manage to spin the cranks without pushing down on them hard at all, there won't be any clicks. When I push on the cranks really hard, I can actually slightly feel the click through the cranks. I am pretty sure this is coming from the BB, though I am open to other ideas of what it could be.
Being new to the bike wrenching thing, I was wondering what the best way to clean out the BB would be. I am aware of resources like the Park Tool website, I was just wondering what others typically do in cases like this. Also, since I have just begun wrenching my bike lately, I don't have a whole lot of tools, so what special tools, if any, would I require?
Thanks in advance!
'09 Race Schedule
Oceanside 70.3
http://ucsdtriathlon.org
trail
Nov 21, 08 17:09
Post #2 of 10 (246 views)
Re: Cleaning the BB [Occam's Razor]
In reply to
Can't Post
At the minimum you need a bottom bracket tool. What kidn depends on what kind of BB you have. The rest you can do with general purpose tools.
After cleaning and re-greasing, there are two school of thought on solving the clicking problem: thread locker and teflon tape. Some people say to use some Loctite on the BB threads, other say lay down some teflon tape before reassembly. I've never had a problem with my BBs so haven't done either myself, however.....
android
Nov 21, 08 17:10
Post #3 of 10 (245 views)
In reply to
Can't Post
Well, there's a half a dozen or more different types of crank assemblies out there, so make and model might help.
Occam's Razor
Nov 21, 08 18:26
Post #4 of 10 (214 views)
Re: Cleaning the BB [android]
In reply to
Can't Post
The bike is a 2008 specialized allez, with (AFAIK):
CRANKSET: Sugino Comp, five arm, polished arms
BOTTOM BRACKET: Sport cartridge, square taper, 68 x 113mm
'09 Race Schedule
Oceanside 70.3
zipp
Nov 21, 08 19:55
Post #5 of 10 (185 views)
In reply to
Can't Post
Actually the click may be a few things:
1. Remove, regrease and re-install your chainring bolts.
2. Check to be sure your crankarms are tight
3. Remove, regrease and re-install the pedals.
4. Remove the cranks and bb and then regrease and re-install the bb and cranks.
Oh, and not necessarily in that order : )
Paul
http://casasedona.com
pito00
Nov 21, 08 21:27
Post #6 of 10 (167 views)
Re: Cleaning the BB [zipp]
In reply to
Can't Post
To further complicate matters, if it's gear dependent it might be coming from your cassette, which means you need to take your cassette off the rear wheel, clean it, regrease each surface that touches anything else, then torque it back down to spec. EVERYTHING NEEDS TO BE TORQUED TO SPEC! YOU CAN MESS UP THE CRANKS ON A SQUARE TAPER BOTTOM BRACKET BY TORQUING THE CRANKS DOWN TOO HARD!!!!
On my way up!
"Drugs are for medical conditions. Being an athlete is not a medical condition."
-Dr. W, WADA
Occam's Razor
Nov 21, 08 22:45
Post #7 of 10 (143 views)
Re: Cleaning the BB [pito00]
In reply to
Can't Post
No, the clicking is not gear dependent, so I'll assume that rules out the cassette.
So basically I just need to remove and re-grease everything on the bottom of my bike. Sounds like fun! ;-)
And I'll make sure to keep the torques to spec. A torque wrench is one of the things I actually do have already.
Thanks for the great info guys!
'09 Race Schedule
Oceanside 70.3
KarlEtzel
Nov 22, 08 4:45
Post #8 of 10 (109 views)
In reply to
Can't Post
One other easy check - make sure your cleats are in good condition and properly tightened.
Silicon Valley Cycling Center
http://www.svcyclingcenter.com
Premium Custom Bikes, Bike Fit Specialists
BikeConcierge - Everything for the Traveling Cyclist
Flak
Nov 22, 08 4:46
Post #9 of 10 (109 views)
In reply to
Can't Post
Just pull the BB and
liberally
apply grease to the threads (don't worry about the rest of the body).
Do that before you waste time doing anything else.
easy-rider
Nov 22, 08 6:26
Post #10 of 10 (85 views)
In reply to
Can't Post
I'm servicing my bikes for ~15 years and went through all kinds of clicking and cracking sounds. Sounds coming from the BB area may be caused by BB itself, loosened crank arm or pedals. Loosened square crank armed is not that uncommon since you can't tighten them as hard as Ostalink or similar cranks. Here are few things you can try before investing into a crank puller and few wrenches. First tighten crank bolts and pedals. Check if there is a play in BB - hold your bike and try pushing/pulling crank sideways. Check if there is a play in pedals - hold crank push pedal up & down. If you find where does the annoying sound come from - disassemble, grease and put everything back. I had clicking sounds coming from looze crank arms when I was using square BB but don't have this problem after switching to Dura Ace 9 speed BB that I tighten well and service twice a year. I bike ~5500 miles a year on my commute bike under any weather conditions and normally get clicking sounds from pedals. If you everything sits tight, greased properly and you still get clicking sounds then you may need to replace your BB. If you put some decent miles on your bike then I'd recommend to start servicing your bike yourself. You can get a pro level kit from Nashbar or Performance Web site for ~100 bucks and enjoy click/crack free rides. If you're new to wrenching thing then you can always look up for information on the Park Tool or Sheldon Brown (what a great guy he was!!!).
Print Thread
The Pro Effect
Which male pro is most likely to influence your buying decisions
Al Sultan
Alexander
Andersson
DeBoom
Frodeno
Gomez
Kemper
Lieto
Lovato
McCormack
Other
Potts
Rapp
Reid
Sindballe
Stadler
Whitfield
