Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Cervelo sizing help
  Tri ForumClassifiedsLavender RoomJobsThe Womens
pito00
Oct 6, 08 9:13
Post #1 of 5 (282 views)
Cervelo sizing help Can't Post
I need the help of the wise-acres of ST to pick a cervelo frame size. I'm 6'3 and have a 34.5 inch inseam. My roadbike frame sizing is a 63cm seat tube w/ a 59.5 cm top tube. I used to ride a Quintana Roo Caliente, but I'm looking to switch to a cervelo. I realize that my longer legs/shorter torso and my pocketbook push me towards the P2C, so I'm wondering if I should pick up the 61cm frame or the 58cm. I'm unsure because Cervelos typically run large.
Can anybody help me?
On my way up!
"Drugs are for medical conditions. Being an athlete is not a medical condition."
-Dr. W, WADA
WiScott
Oct 6, 08 11:01
Post #2 of 5 (238 views)
Re: Cervelo sizing help [pito00] [In reply to] Can't Post
Do you have any "stack and reach" dimensions from your previous QR setup? Is your roadbike setup now with aerobars that you can use the stack & reach dimensions as a starting point?
Recommending a specific frame size based solely on rider height and inseam is pretty much impossible IMHO.
Scott
"It's not bragging if you can back it up."
-Muhammad Ali
pito00
Oct 6, 08 11:03
Post #3 of 5 (235 views)
Re: Cervelo sizing help [WiScott] [In reply to] Can't Post
Sound advice. I guess I need to invest in a measuring tape.
However, my QR didn't put me in as aggressive a position as I wanted b/c of the 76 degree seat angle, so how applicable are those stack and reach #s?
On my way up!
-Dr. W, WADA
(This post was edited by pito00 on Oct 6, 08 11:04)
c50jim
Oct 6, 08 21:06
Post #4 of 5 (150 views)
My son is half an inch taller than you and is happy on a 58 cm P2SL. 61 sounds big unless you slam the saddle all the way forward. I find Cervelo TT bikes to have long reach unless the saddle is all the way forward.
H2Owings
Oct 6, 08 21:52
Post #5 of 5 (128 views)
I am 6'3'' as well but have a 36'' as I am able to stand over a yard stick with my stuff to one side and it fits pretty perfectly. :-) Sorry if that was too much info. Anyway, I ride a 58cm P2C with a bit more seat post out than most and very little spacers.
