Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Cateye double wireless
  Tri ForumClassifiedsLavender RoomJobsThe Womens
Looper
Aug 24, 08 16:13
Post #1 of 8 (383 views)
Cateye double wireless Can't Post
I've been using the cateye double wireless all summer and have had nothing but problems. It mounts on the chainstay and the cadence works fine. However everytime I'm hammering on the pedals the magnet hits the sensor (I guess because the frame is flexing?). If I increase the distance between the sensor and the magnet it's not even remotely accurate.
I'm 2 weeks out from my first IM and I'm fed up with this thing. Should I be worried about trying new equipment at this point in the game? Has anyone else had this problem?
trvfsub2
Aug 24, 08 16:22
Post #2 of 8 (379 views)
Re: Cateye double wireless [Looper] [In reply to] Can't Post
It is NOT your frame flexing......................
silverback
Aug 24, 08 16:42
Post #3 of 8 (362 views)
try a new battery
TAXI
Aug 24, 08 17:58
Post #4 of 8 (333 views)
We experienced the same problem - Shimano wheels flex under pressure.
Place the spoke magnet on the opposite side to normal i.e magnet on same side as cassette.
This worked!
Taxi for young triathlete
Cervelo P3C - Soloist carbon
Col Stewart Tricoach - alive, well and still coaching :-)
Megaburn nutrition.
Looper
Aug 24, 08 19:29
Post #5 of 8 (285 views)
Re: Cateye double wireless [trvfsub2] [In reply to] Can't Post
Ok, it's not the frame. I assumed the rear triangle could move a couple mm. Something is giving somewhere because I've moved the magnet out from 1mm to probably 4mm and it still hits. The wheels are hed 3 so it's carbon fiber all around (frame is QR Seduza). Any ideas?
away
Aug 25, 08 8:25
Post #6 of 8 (226 views)
Dumb question, but if the Hed 3 mounted perfectly straight. I run a Hed 3 on the front and I know mine is more finicky than my training wheels to get aligned properly when clamping the quick releases. When you spin your wheel on the stand does it roll without any wobble?
I've been using the cateye double wireless for years and it's always performed fine. Eats batteries quicker than most units, but that's it.
Side note: I've recently been running a Hed jet disc on the rear for races and had to increase the gap between the received and the magnet as a result of wheel clearance. It wouldn't always pick up the signal being that far apart so I had to get a rare earth magnet (same size, just more powerful) and it works fine.
Onetimepad
Aug 25, 08 20:32
Post #7 of 8 (159 views)
I had nothing but problems with mine. In the space of 8 months, I went through at least 4 batteries. The thing would constantly lose it's connection, so my numbers would be all messed up. On the average 40 mile ride, it would say 36-37 miles. Took it back to LBS to ensure it was operating correctly and they always said it was fine. Eventually, I ust gave up on it and went with a cheap Cateye wired model. It's a shame too...I really like having the 4 screens of data...when it worked.
ADW
- Not sponsored but proudly fueled by Miller Lite (PM), Diet Coke (AM), Skoal Long Cut Mint and Buffalo Wild Wings
tripastor
Aug 26, 08 5:57
Post #8 of 8 (118 views)
I've had some issues with Cateye Double wireless too but this sounds like an issue with the rear wheel. My buddy has a new set of Hed3C's and the rear wheel kept messing up on him. It would rub on the brakes pads and even once on the frame. He sent it back three times and they repaired it and then it happened again and they gave him a new wheel.
Not sure if this helps or muddies the water. I hope it all goes well with the upcoming race.
Off Season
What will you do in the off season?
Bike focus
MTB or 'cross
No training
Run focus
Swim focus
What offseason?
XC ski or snowshoe
