Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Cassette size compatibility with Ultegra rear derailleur?
  Tri ForumClassifiedsLavender RoomJobsThe Womens
DC Pattie
Nov 10, 03 10:58
Post #1 of 7 (178 views)
Cassette size compatibility with Ultegra rear derailleur? Can't Post
I was wondering what is the largest cassete I can put on my road bike. I have a 12-27 but can I use a 11-32 MTN bike XT cassete with an Ultegra derailleur?
Dave from VA
ajfranke
Nov 10, 03 11:13
Post #2 of 7 (165 views)
Re: Cassette size compatibility with Ultegra rear derailleur? [DC Pattie] [In reply to] Can't Post
I tried this once with my DA derailleur. The 28 tooth cog worked great, but the 32 cog clicked badly since the cage wouldn't pull back far enough. I never tired turning that screw that I forget the name of that one would normally never adjust, but the 32 tooth cog is so far out of spec that I never wanted to try it.
You shouldn't have a problem if you just switch to the XT derailleur. These parts are very compatible with the DA/Ultegra stuff.
____
This forum is going to be a place of civil discourse, and those who wish to foment hate and discord are no longer welcome here. -- slowman 11/8/04
Art Franke
Rich
Nov 10, 03 11:20
Post #3 of 7 (160 views)
Re: Cassette size compatibility with Ultegra rear derailleur? [ajfranke] [In reply to] Can't Post
That's the official line from Shimano too. 28 is ok but no more. Anyone know whether switching to a long-cage (triple) D/A or Ultegra will make a 32 work?
________________________________________________
Anyone who tells you they're as fast now as they were when they were 18...
sure wasn't very fast when they were 18.
cerveloguy
Nov 10, 03 11:49
Post #4 of 7 (153 views)
Re: Cassette size compatibility with Ultegra rear derailleur? [Rich] [In reply to] Can't Post
Sounds like you want to race in the Alps. A triple will work fine with a 27 or 28. The 30 cog small gear on the front will get you up any steep incline with a 27/28 rear. Unfortunately to swich to triples you have to also change BB and both derailleurs. Any Ultegra shifters will work but DA must be triple specific. Another easier option is to switch to a 50/34 compact crankset. This was discussed in detail recently. FSA and Stronglight make these cranks. The Stronglight is quite a bargain in comparison although not Shimano BB compatible, so you'll also have to purchase the Stronglight BB.
http://www.xxcycle.com/...amp;FROM=bestwebbuys
"OK, I'll admit I screwed up the facts"
ajfranke
Nov 10, 03 12:27
Post #5 of 7 (135 views)
The longer cage didn't help. The problem is the cage angle, not the chain slack.
If you have the long cage already, why not go with the triple? In Lake Placid I now use the triple front with the regular cage rear. I lose a couple of gears when using the small chain ring since the derailleur is not able to take up enough chain slack, but that is no big deal.
At some point in the future I will probably switch to 10 speeds and the 50/34. My triple works just fine though, so I am in no hurry to do that.
____
Art Franke
ashayk
Nov 10, 03 14:05
Post #6 of 7 (108 views)
An XT/XTR rear der. works great and is fully compatible with STI. Don't know about the 2004, though. You can pick up an XT rear der for ~$35. Cassettes are a tad more expensive.
Hey, now how about that 50/34, 32 combo. Yee haw!
--ashayk
SuperDave
Nov 10, 03 18:23
Post #7 of 7 (78 views)
Re: Cassette size compatibility with Ultegra rear derailleur? [cerveloguy] [In reply to] Can't Post
Ritchey is producing a Shimano Splined 50/34 "compact" road crank for '04.
You can make the Ultegra rear derailleur work up to 29t in the back, backing off the b-tension screw might make you able to hit that 32t, but every other gear would have too much chain gap.
-SD
http://feltbicycles.blogspot.com/
