Calendar
Retailers
Stack & Reach
Custom Geometry Calculator
Online Training Log
MAIN
INDEX
RULES &
LEGEND
LOG
IN
Search
this forum
this category
all forums
for
All words
Any words
Whole Phrase
options
Newsletter Signup
Slowtwitch Forums
Building power on the trainer
Tri Forum
Classifieds
Lavender Room
Jobs
The Womens
Print Thread
weak
Mar 2, 05 6:32
Post #1 of 6 (276 views)
Can't Post
One of my weakest areas is hills whether on the bike or running. I have absolutley no leg strength. Does anyone have any recommendations on how I can build up my legs when I'm on the trainer. Normally I just get settled in on a gear and ride steady at about 90 rpms. Should I change to a higher gear occasionally and let the rpms drop down or maybe keep the rpms at 90 and just down shift once my heart rate gets to certain point. Normally when I'm on the trainer I keep my heart rate at 135-140 which is very managable. I have not done anything to find out what my true max heart rate is I just use the old standard 220-age which puts me at 190. Any advice or input would be greatly appreciated.
Weak
gtingley
Mar 2, 05 6:42
Post #2 of 6 (260 views)
Re: Building power on the trainer [weak]
In reply to
Can't Post
To find your heart rate training zones, you can conduct a Conconi test.
Try repeated intervals of 80% of your AT x 6 mins ea(60 RPM), with 3 min recovery between.
- Gary
Rotor Q-Rings - Slowtwitch exclusive 15% discount on sets of Q-Rings
. Use code "slowtwitch" online at checkout at
http://www.RotorCranks.com
, all items in stock, and always FREE UPS Ground shipping!!
JBergland
Mar 2, 05 6:48
Post #3 of 6 (244 views)
In reply to
Can't Post
Try doing some power intervals... 5 min. on, 5 min. off. Shift to the biggest gear you have (53/52-11/12) and crank away at no lower than 50 RPMs. Don't worry about HR... it shouldn't be that high. After 5 min. shift out of the big cookie and down a couple gears, spin at 90-100, resting. If your knees get sore, try grinding away at a higher RPM, although don't let your HR get to high.
JB
Chunky Lover
Mar 2, 05 6:52
Post #4 of 6 (234 views)
In reply to
Can't Post
in addition to increasing resistance and lowering cadence, my coach has me put a couple bricks under my front wheel. And stay in the saddle.
I'm not sayin', I'm just sayin'
STP
Mar 2, 05 7:15
Post #5 of 6 (205 views)
In reply to
Can't Post
I did the Carmichael "Climbing" video workout for the first time last night. My legs hurt this morning so I assume he is on the right track. Here it is the work out from the tape:
5 min warm up
2 x 5 minute "muscle tension" intervals w/ a 5 min easy spin in between. Shift up to a really big gear and grind away at 50-55 rpm for 5 minutes. Don't worry about your heart rate.
Do a 5 min very easy spin 90-95 rpm
2 x 10 "climbing" intervals w/ 5 min easy spin in between.
The first is a straight 10 minutes at 60-65 rpm keeping your heart rate near but not above your lactate threshold.
5 min easy spin
For the second 10 minute interval, change your cadence every minute alternating between 65 for one minute then 95 rpms for the next minute. Keep your heart rate the same (near but not above your lactate threshold) throughout the interval.
5 minute warm down.
davetallo
Mar 2, 05 9:15
Post #6 of 6 (119 views)
In reply to
Can't Post
I've been lovin' this program lately.
http://www.cruciblefitness.com/...orce-me-guidance.htm
Print Thread
