Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Bontrager Aero TT tire Source?
First page Previous page 1 2 Next page Last page  View All Tri ForumClassifiedsLavender RoomJobsThe Womens
jeremyb
Nov 2, 09 17:14
Post #1 of 26 (1012 views)
Bontrager Aero TT tire Source? Can't Post
Anyone have a source for the Bontrager TT tire for less than $60 a tire?
Plus One Lap Cyclocross ||| JeremyBurlingame.com
Red Devil
Nov 2, 09 17:20
Post #2 of 26 (1002 views)
Re: Bontrager Aero TT tire Source? [jeremyb] [In reply to] Can't Post
At my shop ..... $55
My Website
HEDmafia.com
Team First Endurance
SCOTTinNJ
Nov 3, 09 12:22
Post #3 of 26 (901 views)
Re: Bontrager Aero TT tire Source? [Red Devil] [In reply to] Can't Post
In Reply To:
Online source?
Trek Madone 5.9SL
Felt B12
Flanagan
Nov 3, 09 12:42
Post #4 of 26 (876 views)
www.bontrager.com
that's where i got 'em
applenutt
Nov 3, 09 12:52
Post #5 of 26 (858 views)
Unless you get a shop discount at your Trek/Bontrager dealer, you're not going to find them any cheaper online. Trek only deals through walk-in shops and no online ordering except through their website.
www.teamkattouf.com
"Online Nutrition, Fitness, Sport, and Life Coaching"
kemp
Nov 3, 09 14:33
Post #6 of 26 (807 views)
Re: Bontrager Aero TT tire Source? [Flanagan] [In reply to] Can't Post
It figures that their own web site does not have the most commonly needed size in stock. No 700x23's.
Team Triabetes
jackmott
Nov 3, 09 14:48
Post #7 of 26 (797 views)
Re: Bontrager Aero TT tire Source? [kemp] [In reply to] Can't Post
if it helps the 19s are really comfy anyway
In Reply To:
What is good in life? - To crush your enemie's dreams, see them dropped behind you, and to hear the lamentation of their women!
Sunglasses: http://www.framesdirect.com/sunglasses
Tri Gear: http://www.atctrishop.com
Cheap Disc Wheel - http://www.wheelbuilder.com Tire Crr Data - http://www.biketechreview.com
Tom A.
Nov 3, 09 14:49
Post #8 of 26 (795 views)
Re: Bontrager Aero TT tire Source? [jackmott] [In reply to] Can't Post
In Reply To:
In Reply To:
...and faster overall, too.
AFM
Nov 3, 09 15:03
Post #9 of 26 (780 views)
There was a thread a few weeks ago in which a source in Europe was identified. Good price IIRC but shipping might be expensive unless you can find some friends to make a group buy.
BMAN
Nov 3, 09 17:13
Post #10 of 26 (741 views)
Re: Bontrager Aero TT tire Source? [Tom A.] [In reply to] Can't Post
But only when used on the front correct while the 23 on the rear is faster. I have been following your post long enough to know better I think.
Aero & Light is Right
SLC 2.0
jackmott
Nov 3, 09 17:18
Post #11 of 26 (730 views)
Re: Bontrager Aero TT tire Source? [BMAN] [In reply to] Can't Post
well step 1 is does this tire match gloriously with your rim?
the 19mm matches the NON C2 Hed Jet90 perfectly
the 23mm does not meld all that gloriously with my cheap as normal rear wheel, don't know if the 19mm does, haven't tried it.
I think its mostly speculation, or educated guess as to whether the 23 or 19 is better in the rear.
Its probably splitting hairs that are pretty thin =)
I went with 23 in the rear just in case that gives me more comfort and flat resistance. But then my rear wheel is nicely covered up by my frame =)
In Reply To:
(This post was edited by jackmott on Nov 3, 09 17:20)
Tom A.
Nov 3, 09 17:19
Post #12 of 26 (730 views)
In Reply To:
Maybe...but if you're going to use a 23 on the rear since tire/rim aerodynamics effects may be lessened, then there are a lot better rolling 23c tires than the Aerowing TT.
IRONwolf
Nov 3, 09 17:50
Post #13 of 26 (697 views)
I have a set with about 100 miles on them that need to go (23)
As it turns out, what you have is less important than what you do with it...
-Bernd Heinrich, why we run
MOP_Mike
Nov 3, 09 17:53
Post #14 of 26 (692 views)
In Reply To:
In Reply To:
So...I have a C2 Jet 60 front. 19 or 23 for this bad boy?
"...Sometimes it's about getting the most speed out of the motor you have." -- Tom A.
(This post was edited by MOP_Mike on Nov 3, 09 17:54)
jackmott
Nov 3, 09 18:00
Post #15 of 26 (683 views)
Re: Bontrager Aero TT tire Source? [MOP_Mike] [In reply to] Can't Post
neither one really achieves a seamless transition from wheel to rim from the pictures I've seen posted here.
19 is going to be faster up front regardless probably but, you might consider other 19mm front tires if some have better rolling resistance, since the wing feature + C2 rim doesn't work out so hot.
In Reply To:
MOP_Mike
Nov 3, 09 18:04
Post #16 of 26 (677 views)
In Reply To:
In Reply To:
Yah. Thanks, that's what I recall from the other thread. I was hoping I was wrong. :(
I'm running 21mm Zipp clinchers right now, but I suppose there are lower Crr tires to choose from. I wonder what kind of puncture resistance I'd give up with the lower Crr choices, though...
Interestingly enough, I have a non-C2 jet disk in the back of my non-seatposted Titanflex and so might benefit from a TT 19 in the rear...
jackmott
Nov 3, 09 18:06
Post #17 of 26 (674 views)
that zipp tire ain't bad, probably not worth messing with.
sadly you can't really know if the aero-TT works out well with a wheel until you try it
non-c2 hed jets are cheap used though =)
BMAN
Nov 3, 09 20:27
Post #18 of 26 (626 views)
Well since the thread is about the Bontrager tires only, would you say that it would be better to have the 19mm upfront and the 23 in the rear for the best set up on these tires or would you go with 19mm all around or 23 all around.
SLC 2.0
Tom A.
Nov 3, 09 20:35
Post #19 of 26 (620 views)
In Reply To:
Personally, I go for the 19s front and back...but if I was going to run a 23 on the back, I'd go with something that has a lower Crr and basically the same "robustness", like the Bontrager RXL Pro 23 if you want to keep it in the Bonty family...
Pantelones
Nov 3, 09 21:02
Post #20 of 26 (606 views)
Here is a 19mm TT on my Hed 60 C2. I love it and think it transitions well.
p.VDB
Nov 4, 09 0:30
Post #21 of 26 (575 views)
Re: Bontrager Aero TT tire Source? [AFM] [In reply to] Can't Post
In Reply To:
But be carefull for getting the "older" bontrager aero TT tire. I bought this summer 3 bontrager aero TT 19mm tires but all three were > 200 gram. So I am also interested to know were can I buy the new bontrager tires online in America? Because bontrager.com doesnot sell to europe :-(
___________________________________
Paul | Medisch Info | Medisch Zoeken
renegade027
Nov 4, 09 1:39
Post #22 of 26 (562 views)
I think you are talking about http://www.allterraincycles.co.uk/
But they've adjusted their price since then - it's no longer £18 ($30ish) but £27 ($45ish), which with shipping would be in line with the US price.
jeremyb
Nov 4, 09 3:48
Post #23 of 26 (538 views)
In Reply To:
In Reply To:
Exactly what I was going to do.
p.VDB
Nov 4, 09 9:41
Post #24 of 26 (448 views)
Re: Bontrager Aero TT tire Source? [renegade027] [In reply to] Can't Post
Do they have the "new" bonty RXL TT Wing?
docfuel
Nov 4, 09 13:09
Post #25 of 26 (405 views)
Trek shops can usually order them.
_________________
Dick
Take everything I say with a grain of salt. I know nothing.
Are equipment rules important?
What organization's rules do you seek to comply with before you purchase bikes, wetsuits, etc.?
UCI
USA Cycling
UCI/USAC
WTC
USAT
WTC/USAT
ITU
All
None
