Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Best road fork?
  Tri ForumClassifiedsLavender RoomJobsThe Womens
cerveloguy
Feb 24, 05 15:54
Post #1 of 14 (299 views)
Best road fork? Can't Post
My new Lemond OCLV/steel frame just arrived. It's a beauty and will replace my aluminium TCR frame.
Can't use the Giant TCR fork since it's 1" and the Lemond is 1 1/8" steerer.
Thinking of getting a Reynolds Ouzo Pro fork. Seems like a good choice?
Any other suggestions to be considered?
"OK, I'll admit I screwed up the facts"
sharad
Feb 24, 05 16:04
Post #2 of 14 (288 views)
Re: Best road fork? [cerveloguy] [In reply to] Can't Post
Get the Reynolds. Might take a look at Easton's forks as well but Reynolds is a killer fork and you won't regret the purchase.
I sell both, let me know if you are interested in either.
- Steven H -
Kestrel Brand Manager
www.kestrelbicycles.com
www.kestrelbicycles.wordpress.com
215.824.3854 Ext. 1111
jcurtis
Feb 24, 05 16:08
Post #3 of 14 (280 views)
Not all forks have the same dimensions (height, rake, etc.). Match the dimensions of the fork with the needs of the frame. Call Lemond and see what they recommend as far as replacements go. If the fork is too long or too short, it will change the handling of the frame. Ditto rake changes vis a vis original spec.
that said, the Ouzo Pro is a great fork ... I've got two ... one on an eddy Merckx and one on a Steelman.
"In case of flood climb to safety"
(This post was edited by j-son on Feb 24, 05 17:03)
Smil'n Hawaiian
Feb 24, 05 16:14
Post #4 of 14 (274 views)
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out,  shouting, holy crap, what a ride!!" - author unknown
king1
Feb 24, 05 17:06
Post #5 of 14 (242 views)
Do you not like the stock Bontrager fork?
There are quite a few nice forks on the market. Just make sure you get the correct one for your riding style.
Also, I would stick to the same rake as the stock fork for your Lemond frame size. I think it's 45deg. for most or all sizes in steel/oclv line.
(This post was edited by king1 on Feb 24, 05 17:13)
GDNenn
Feb 24, 05 17:26
Post #6 of 14 (223 views)
Ouzo Pro, I put one on my aluminum Pinarello and it felt great compared with the stock carbon fork.
Geoff at Colorado Multisport
www.coloradomultisport.com
boulderTRIATHLON Coaching, Powerbar
XFalcon
Feb 24, 05 17:40
Post #7 of 14 (212 views)
Re: Best road fork? [GDNenn] [In reply to] Can't Post
Ouzo Pro Lite -- Matte finish. Some other nice forks out there, but you cant go wrong with Reynolds.
Loveless Babies
Feb 24, 05 18:27
Post #8 of 14 (185 views)
Re: Best road fork? [cvillatri] [In reply to] Can't Post
When you come to a fork in the road...take it.
cerveloguy
Feb 24, 05 19:02
Post #9 of 14 (169 views)
A picture is worth a thousand words, but that one is scarey. Please tell me that's not a Reynolds Ouzo Pro.
cerveloguy
Feb 24, 05 19:07
Post #10 of 14 (165 views)
Re: Best road fork? [king1] [In reply to] Can't Post
"I would stick to the same rake as the stock fork "
It is 45, the same as the TCR fork. The Reynolds also is available in 45. I have a line on a new 43 for a psalm. Do you think that 2mm will make that much difference?
rroof
Feb 24, 05 20:31
Post #11 of 14 (135 views)
I'll also add a rec for the Ouzo Pro - very siff, durable and reasonably light.
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
jcurtis
Feb 24, 05 22:20
Post #12 of 14 (105 views)
It's not just rake you should look at ... also, fork height. Not all forks are the same height. This is especially true for carbon forks.
Realistically, 2 mm won't make that much difference. But, 2 mm less rake plus (or minus) a cm in height could change the front end geometry quite a bit resulting in a bike that handles oddly at high speeds.
DC Pattie
Feb 25, 05 4:50
Post #13 of 14 (73 views)
If I were building a new road bike I would pick the new Look HSC 5 SL first and the Easton EC90 SLX second.
Dave from VA
Helitech
Feb 25, 05 5:15
Post #14 of 14 (65 views)
I second the geometry warning , I have a " Look "carbon fork ,that has less rake than the original . At high speed scary fast response steering. Get a bit of curve on the bottom , straight blades-raked out ride a bit harder.
The Pro Effect
Which male pro is most likely to influence your buying decisions
Al Sultan
Alexander
Andersson
DeBoom
Frodeno
Gomez
Kemper
Lieto
Lovato
McCormack
Other
Potts
Rapp
Reid
Sindballe
Stadler
Whitfield
