MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
Asics Speedster 3
Fork-Um
Oct 27, 08 7:54
Post #1 of 12 (2872 views)
Asics Speedster 3 Quote | Reply
So I've been running in the Speedster 3 the past couple of weeks and like them. Not sure I could run a marathon in them. So my question is what shoes should I look at that have a little more cushion and structure. Oh yeah I do use orthodics so I usually don't need a monster stability shoe. Thanks
Chris G
Oct 27, 08 8:00
Post #2 of 12 (2865 views)
Re: Asics Speedster 3 [Spider] [In reply to] Quote | Reply
Check out the Landreth. That is what I use for an every day shoe. It is still pretty light. I would have no problem using the Speedstar's for a marathon. Used them for IM this year. Would run in them all the time but they wear out really fast.
Fork-Um
Oct 27, 08 8:15
Post #3 of 12 (2849 views)
Re: Asics Speedster 3 [Chris G] [In reply to] Quote | Reply
Durability was my issue with the speedsters. So I figured if I had a shoe I could rotate with the speedster that would help. I looked on Asics website and they have the Landreath, nimbus, and cumulus as the same category as the speedsters so I figure I check those out. The speedsters are the first Asics I have used. In the past I have run in Saucony but the last few my orthodics haven't fit in them well so I took the plunge and switched. So far I am happy we'll see.
kdw
Oct 27, 08 8:45
Post #4 of 12 (2831 views)
I put orthotics in ds-trainer 13s and run everything on them. Races, long runs, speedwork. They are only .2 ozs heavier than the speedstars.
You would probably want .5 size bigger in the trainers than the speedstars.
mmrocker13
Oct 27, 08 8:48
Post #5 of 12 (2824 views)
DS Trainer is pretty much the same shoe, but with a bit more stability. Order a full size larger than your speedstars.
mmm-mmm-Momo Charms
Handmade beverage charms, jewelry, and miscellanea
http://momocharms.wordpress.com
Fork-Um
Oct 27, 08 9:07
Post #6 of 12 (2810 views)
Re: Asics Speedster 3 [kdw] [In reply to] Quote | Reply
Do you recommend the bigger size because of the orthodics or just because they run small?
kdw
Oct 27, 08 9:16
Post #7 of 12 (2801 views)
A little bit of both, but I guess mostly because they run small.
Ray G
Oct 27, 08 10:20
Post #8 of 12 (2757 views)
I also recommend ordering a full size up on the DS Trainer. I wear 2130's and Speedsters (which I thought were too light) so I bought the DS 13's which worked out for the marathon I ran last week. I might run my next marathon in the Speedsters though since even with the upsizing the DS's feel a little small. All my previous Asics are 9.5 's (US) and my DS's are 10's.
Ray
bella
Oct 27, 08 11:16
Post #9 of 12 (2729 views)
I use the Speedstar too. I would rec. the Nimbus 10, it is softer than the Landreth and will provide enough room for your orthotic. Plus with the new design at the toe box, they will fit a little better than other Asics which tend to offer more room in the toe box.
S
Fork-Um
Oct 27, 08 11:30
Post #10 of 12 (2709 views)
Re: Asics Speedster 3 [bella] [In reply to] Quote | Reply
A roadrunner sports retail store opened not to far from me so I figure I'll check all the recommendations out rather than having to order them.
Thanks
alex_m
Oct 27, 08 11:46
Post #11 of 12 (2698 views)
I rotate between a set of Asics Kayano 13s and DS-Trainer 13s for training. I love the both but find the Kayanos to heavy/cushy/structured for any kind of speed work. I bought the DS-Trainers one full size up as seems to be the norm. I use them for running marathons without any issues and find they offer a great balance between cushioning, lightweight and support. For a half IM and shorter events, I absolutely recommend the Asics Gel-Bandito. It is a structured racing flat. It runs true to size and is ridiculously light at 7.9 oz. I have done sprints, olympics and plenty of speed work in them. I have not worm them during a marathon length event. Hope this helps. As a reference, I have flat/narrow/low volume feet and I am a mid-foot striker... if any of that stuff matters.
coming soon...
mmrocker13
Oct 27, 08 12:13
Post #12 of 12 (2680 views)
In Reply To:
They run very small. I am a 7.5; wear a 7.5 in Speedstars. Always was an 8 in DS Trainers until the 13s--now am an 8.5.
mmm-mmm-Momo Charms
The New Specialized Wind Tunnel
Will this be a game changer for Specialized, in both sales and product design, or will it not move the sales and design needle versus those in Specialized's competitive set?
Yes, Game Changer
Minor move forward
Won't budge the needle
