Slowtwitch.com Main Index MAIN
INDEX
Forum Rules & Legend RULES &
LEGEND
Log in LOG
IN
Search for (options)
Newsletter Signup
Slowtwitch Forums: Triathlon Forum:
Aero Front or Rear??? Can't have both though..
  Tri ForumClassifiedsLavender RoomJobsThe Womens
Brent 1
Aug 24, 08 18:20
Post #1 of 4 (280 views)
Aero Front or Rear??? Can't have both though.. Can't Post
Hypothetical question, If you could have either a disc in back or a trispoke up front but not both which would be best to race on/would help you the most? Assume that the other wheel I solid quality wheel such as a Mavic Elite and that the race is a half ironman distance rolling course with light/moderate winds.
MOP_Mike
Aug 24, 08 18:35
Post #2 of 4 (254 views)
Re: Aero Front or Rear??? Can't have both though.. [Brent 1] [In reply to] Can't Post
For a given wheel depth, the greatest aero benefit will come from the front wheel as it sees "clean" air.
That said, you can run a deeper wheel in the back (i.e. a disk) to partially offset this. This is most beneficial at high yaw angles (windy conditions).
Also, a deep front wheel and skinny rear can be difficult to handle in sidewinds.
A trispoke in particular performs best at high yaw angles where it is especially difficult to handle. So in your specific light/moderate wind scenario, I'd choose a very deep, non-trispoke front (Z808, HED 90, Z1080, etc). If you *had* to choose between a trispoke front and disk rear for those conditions, I'd choose the trispoke as even at low yaw angles where it's not the best, it's still better than a skinny rim.
In windier conditions, I'd pick the rear disk over any aero front wheel.
"...if you are pedaling correctly, it doesn't matter what cranks are on your bike." -- Frank Day
(This post was edited by MOP_Mike on Aug 24, 08 18:39)
BMAN
Aug 24, 08 18:37
Post #3 of 4 (250 views)
Easy answer is tri-spoke on the front. Better to have a more aero wheel to slice through the air.
Not so easy answer. Tri spoke might be slow depending on the fork and bike design so a 60mm or 90mm might be faster actually and depending on where the race is.
Aero front makes more sense.
Aero & Light is RightWink
seanathan
Aug 24, 08 18:46
Post #4 of 4 (224 views)
tri spoke up front
get a wheelcover for the rear
Yes. Always punch people in the face when their interests are different than yours. There can be no other way.
-one_lap
